G35 & G37, Coupes & Sedans
Pressure Washer Owned My G
Old Jun 21, 2006 | 09:34 AM
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by 06BLACKMT
lol man, PRESSURE washer + soft paint = sole complaint to yourself, not infiniti. My power washers rips the siding off my house..if i was to ever use it on my G itd be from 20 feet away on a wide spray...
better get some touch up paint
+1, couldn't agree more.
When you are using a pressure washer on your G, you are taking a very BIG chance IMO. I would NEVER wash my G with a pressure washer......for the very reason you experienced.
Using a pressure washer for taking paint off a deck is good.....not taking paint off a G!
Old Jun 21, 2006 | 09:56 AM
Originally Posted by BADG35
Doesn't surprise me... Infiniti's paint is the worst in the world... I won't even get into it... I just might puke....
Good Luck man!
BADG35
Look at the narrow pattern of paint that was taken off his G, his pressure wand definitely got tooooo close to his car. You put a pressure washer on any paint that close and it will do the same thing.....not just Infiniti paint.
Old Jun 21, 2006 | 10:01 AM
JEVERYDAY's Avatar
Not something I would have done
Old Jun 21, 2006 | 10:09 AM
Bigd2k6's Avatar
judging from the pictures, it looks like a bumper. bumper = plastic and we all know (at least some of us) that paint will not adhere to plastic as well as it would metal. this is your own fault. just go to the dealer and don't tell them what happened so they can fix your screw up for free. lying is the thing nowadays, right? how does the phrase go? get something for nothing?
Old Jun 21, 2006 | 10:41 AM
05Scoobyroo's Avatar
I use the pressure wash at the local hand car wash all the time, never, ever pull the trigger to get extra pressure using it on the car. Two washes after pressing the trigger, it will impact the wax CLEAR off of the car!!!
Old Jun 21, 2006 | 12:04 PM
PotomacG's Avatar
Originally Posted by M4Gunner
....run your hand under it. if its hurts, youre either a girl or the pressure is up too high, and your G wont like it either.
And while you're at it, stick your finger into that light socket to check if the bulb is really burned out.
PSI high enough to remove paint from your bumper is also high enough to cut your flesh wide open.
Read the damn precautions people.
Old Jun 21, 2006 | 01:44 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by Chico
I use a pressure washer as well sometimes without any problems. You should bring the car back to Inifini and put in a claim for it, but do not tell them you used a pressure washer or they'll simply refuse to fix it under warranty.
I'd be inclined to try this, and then ditch the p/washer or at least stand back further.
C.
Old Jun 21, 2006 | 03:48 PM
Woblin_Goblin's Avatar
Agreed. Never blast yourself or someone else with a pressure washer. They've cost people their eyes, ripped out toe nails, etc.
I use a lower pressure nozzle to hit the wheel wells and underneath the car.
I suspect the higher pressure nozzle took some paint off near one of the rear wheels. Although it is hard to tell, they look like chips and are in an area that probably gets hit often. In any case, I've done my best to fix the imperfections and I haven't used it (the high pressure one) since.
Old Jun 21, 2006 | 04:01 PM
ericsherbrooke's Avatar
Originally Posted by jiggalam
Ouch. Note to self never use a pressure washer on the car.
same here... just learn something today...sorry for the OP
Old Jun 21, 2006 | 04:18 PM
shibal_z's Avatar
No MACHINES!!!! Our baby Gs require soft supple HAND washing and detailing to gently massage dirt and debris off of the smooth and sensual clearcoat. Aren't you HOT for your G? Go give her the wash that she deserves... LOLZ...
Old Jun 21, 2006 | 07:38 PM
jackygor's Avatar
God damn it...i guess some people have to to learn it the hard way =(...at least the only thing i got out of this is warn you guys not to wash the G with the pressure washer =/
So i guess using touch up paint is good?
solution anyways?
Old Jun 21, 2006 | 07:44 PM
Otacon132's Avatar
i have an electric pressure washer - which on its wide spray setting doesnt harm my car - i hardly use it though
Old Jun 21, 2006 | 09:03 PM
Skyline_G35's Avatar
English dude, English
Yeah, don't put your hand under the pressure washer. Pressure washers put out an extraordinary amount of psi just like paint sprayers for painters. Water or paint injected into the skin might have a chance to make it into your blood stream = possible death.
Old Jun 21, 2006 | 10:39 PM
Skaterbasist's Avatar
Retired SuperMod
Wow that sucks.
Seems like the pressure was strong enough to remove tagging off sidewalks. Well maybe not that strong but I would never use a pressure washer on my car.
Old Jun 21, 2006 | 11:29 PM
  #30
I used a pressure washer on my pool deck and it took the kool decking right off!!! That was a fun day.
