G35 & G37, Coupes & Sedans
What do you do with hot air from steering column
Old Jul 16, 2006 | 12:15 PM
andy2's Avatar
I heard this happens to all G35 model. What do you do? Just put up?
Can there be a fix? I talked to my dealer but they said that is the way it is designed and there is nother they can do about it.
Old Jul 16, 2006 | 01:47 PM
Calvin's Avatar
Overglorified Altima
i thought i was the only one..
Old Jul 16, 2006 | 03:44 PM
Msedanman's Avatar
O.F. Administrator
You're getting hot air leak thru from the engine compartment thru the battery box.
What you have to do is seal that box up well so there are no leaks.
C.
Old Jul 16, 2006 | 03:47 PM
absolutg's Avatar
workin...
isn't the battery on the passenger side??
Old Jul 16, 2006 | 05:05 PM
RBull's Avatar
Rated M
C.
Are you talking about that large opening behind the battery on the firewall? The way it's designed it looks like it has some purpose. If it doesn't I will seal mine up too.
Old Jul 16, 2006 | 05:27 PM
andy2's Avatar
What would you use for sealant that without odor? Don't want to stink up the whole car.
Old Jul 16, 2006 | 07:04 PM
Msedanman's Avatar
O.F. Administrator
Deane, I'm refering to the tray/box that the battery is in, not the opening behind it thru the firewall.
C.
Old Jul 16, 2006 | 08:12 PM
RBull's Avatar
Rated M
^ okay thanks.
Old Jul 23, 2006 | 12:54 AM
BW350GTskyline's Avatar
wut up.. wen i first read the thread i was like no way i thought i was just feelin a difference in temperature in the car but thats really weird nd makes sense why i feel that burst of warm air...
Old Jul 25, 2006 | 12:10 PM
andy2's Avatar
Tried to seal up the battery box but did not work. I think it's something else. Maybe there is not enough heat insulation at the driver's area. Maybe there are other leakage besides the battery box.
Also, there is a what seems like a vent that is at the upper left corner of the battery box which is there for a purpose that should not be sealed.
Old Jul 25, 2006 | 02:45 PM
GT-Ron's Avatar
I'd like to see someone point out in pics the locations that need to be sealed. It would really help.
G35Rican
Jul 31, 2024 01:37 AM
DG2Door
Sep 11, 2015 08:04 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Kicknshift
Sep 3, 2015 09:35 AM
