G35 & G37, Coupes & Sedans
Downshifting Question on Hills
Old Jul 19, 2006 | 05:09 PM
mal_TX's Avatar
the amount of fuel being injected is depedent on the engine's ability to consume it..
that means that if you are in 6th gear going 20mph and floor it, it is NOT using a bunch of fuel.... if you get a feel for how much flooring it at 20mph does for you acceleration-wise... and then accelerate exactly that same way in 2nd gear instead (at high rpms), you will use ALMOST exactly the same fuel.
burning fuel to create power... that hurts your mileage. coasting the engine (foot off the gas) or barely accelerating at moderate revs (3k-5k) does not use more fuel than coasting in Neutral or barely accelerating at low revs.
if you have navi try watching your realtime fuel consumption display on the fuel economy screen.
higher revs are harder on your engine than low revs, but not exceedingly so unless you're talking about constantly redlining. so... up the hill... use whatever gear you want, it's about the same mileage wise.. the only difference is your ability to accelerate and how much you are beating up your engine. anything between 2-5k rpm should be acceptable in either case. going down the hill, selecting a gear that gives you rpms in that same range will save your brakes and use NO fuel.
Old Jul 19, 2006 | 05:52 PM
obender66's Avatar
You need to be able to control the car and have enough power to merge or pass on uphill. This may or may not involve changing gears.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
