how to remove steering wheel with out airbag going off?/
doing and interior swap want to know how to remove the steering wheel with out setting the airbag off and losing 1k you help is greatly appreciated!
You can try disconnecting the aibag module. First you need a TORX bit to take off the two screws on the side of the steering wheel. Then pull the airbag module out and unclip the tabs off the orange and yellow plugs. Now the airbag module is disconnected. Ofcourse, ensure the battery is disconnected while you're doing this.
What kind of interior work are you doing?
is it absolutely necessary to buy new torx screws like the manual says? how many lbs of tq did you tighten them at?
nice.. i'm doing the same. I'm about the put the orange stich 05 steering wheel on. let us know how the rest goes.
the manual states you should completely disconnect the battery for 3 minutes then you can disconnect the airbag. handle with care of course
I had an 05 and put on the Nissan airbag cover... the dealer installed a special bolt, almost like a small wheel lock (not the torx security bolt), that can only be removed at the dealer (which they wont do). I had to drill out the bolt, and use the torx security bit on the other bolt (can buy this at sears or any auto supply store) - was a real hassle. Just make sure you unhook the battery for at least 3 minutes (I think that's what the manual says), and you'll be fine.
Luisgalvan33
Jul 19, 2018 08:16 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
