G35 & G37, Coupes & Sedans
View Poll Results: What kind of gas do you use?
Super
202
90.58%
Mid
3.59%
Reg
13
5.83%
Voters: 223. You may not vote on this poll
Old Aug 22, 2006 | 11:37 PM
  #31
tomcatm's Avatar
Originally Posted by shellguy05
There is no difference in the actual gasoline itself, Its the additives that they put into the gasoline before it gets delivered to the stations. Which is why the V-power is the best gasoline out there. This additive increases fuel economy and also keeps your engine clean. Plus its a 93 octane which is excellent in its own.
^+1
V-power all the way! Sign up for the Citi Shell MasterCard and save another 5% on gas (premium for regular price)
ShellGuy, what OU do you work for? I am at Downstream Controller's in OSP Houston btw.
Old Aug 23, 2006 | 12:04 AM
  #32
RRF985's Avatar
My mom was running 87 until she finally got tired of me telling her to run 91. Once she did she noticed a big difference as well as a huge increase in gas mileage. I'm happy and she's happy she switched now. Realized that it was only about 10-20 tanks on 87. Chevron 91 now. Nothin but the best for the G.
Old Aug 23, 2006 | 08:22 AM
  #33
kevink's Avatar
What year G35 was this? Sedan or Coupe?
I understand that the Coupe has always required Premium. At least the 2003-4 Sedans didn't.
Old Aug 23, 2006 | 08:42 AM
  #34
majorbta's Avatar
The quality of gas between an 87 and a 91 or 93 should be the same. The difference isn't that one is inhernetly better than the other, the difference is that they brun at different rates.
And for whoever said that their "car made a funny noise when regular was in it, but fine when premium was in it", that is pinging my friend. When a car is designed, either from the factory or because of an aftermarket tune, to run 91+ because of increased timing etc.., it will make "funny noises" if you don't run 91+, and even kill your engine.
Old Aug 23, 2006 | 09:22 AM
  #35
fortified's Avatar
Originally Posted by EZZ
I believe if the mfg recommends premium and you keep sticking in 87, you're outta luck if engine failure occurs. I hear engines run a pretty penny.
Could not agree more!
Old Aug 23, 2006 | 09:23 AM
  #36
GTScott's Avatar
I use the premium (93 here in Atlanta) and noticed Saturday night that under load, with the AC on, I was getting some *slight* pinging. I can't imagine running with anything less.
Old Aug 23, 2006 | 06:39 PM
  #37
Msedanman's Avatar
O.F. Administrator
Originally Posted by RBull
The person at your dealer saying that is not competent. Running regular is not recommended and can cause problems with pre ignition and engine damage.
Good thing you made the decision to follow the manufacturer recommendations.
+1....... only premium goes into mine.
C.
Old Aug 23, 2006 | 10:47 PM
  #38
inspector_yoo's Avatar
When gas was rising in the past, I confess I used 89 for a little while. I believe less then 10 tanks. But when I guess I started hearing pinging, I immediately switched over to 91. Hopefully, i didn't damage the engine too much from doing that.
Dumb mistake well learned.
Old Aug 24, 2006 | 01:22 AM
  #39
Woblin_Goblin's Avatar
In this part of Alberta 91 is premium. I think elsewhere premium must be 93 right? Anyways, I fill up with 91. On occasion I've used 89 in locations where gas prices are insane. Once and awhile I've been stuck with 87 when anything higher isn't available or sold. Didn't notice any problems (sedan should be fine according to the manual) and the car runs as good as the day I bought it.
Old Aug 24, 2006 | 03:29 AM
  #40
Skaterbasist's Avatar
Retired SuperMod
Premium always
Old Aug 24, 2006 | 10:11 AM
  #41
G35Banker01's Avatar
Amoco BP is the only gas I use 93octane!!!!!!!!!!!!!!!!!!!!
Old Aug 24, 2006 | 10:44 AM
  #42
350Zed's Avatar
Exclamation
Guys, guys, guys...
This is really simple, so let me spell it out for you.
The VQ35DE ECU is tuned for 91 octane gasoline.
If you run lower-octane fuel, the ECU retards timing, reducing peak power output. If you run higher-octate fuel, the ECU does not advance timing past the factory-tuned maximum and you are just wasting your money.
Haven't any of you ever worked on a carburetor and manually-timed an engine with a timing light? The principle is the same.
The moral of the story, kids, is run 91 octane like the little book that comes with your car says.
Old Aug 24, 2006 | 11:53 AM
  #43
tomcatm's Avatar
Yeah but lot of places dont have 91 Octane. I only get 93 so I dont have a choice, but my timing is bumped to 17 degrees so I am glad to take the 93.
Old Aug 24, 2006 | 03:42 PM
  #44
mephistomyhero's Avatar
Wow, some places have 93 but not 91? That's really odd. Were's the next grade down? 89? Here in Southern Cali, it's 87, 89, and 91 (premium). I've only used the top three Mobile, Chevron, and Shell. I like Mobile and Chevron the best and mostly fill up on Mobile Premium.
Old Aug 24, 2006 | 03:49 PM
  #45
350Zed's Avatar
Here in Toronto you'll see this:
Sunoco - 87, 89, 91, 94
Esso - 87, 89, 93
Petrocan - 87, 89, 91
Different distributors carry different grades, but they all market high-octane fuels as "better" for all cars, when this is not in fact true. Most cars will not take advantage of higher-octane fuels than they are tuned for by the factory (i.e., the minimum recommended grade specified in the owner's manual).
Just pick 91 (or the next higher available) and you'll get just what you need for your G.
