G35 & G37, Coupes & Sedans
oil change ..LEAKING OIL..HELP
Old Oct 8, 2006 | 05:37 PM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
I went to GLENDALE infiniti for a oil change... THEY SUCK
I notice there A small spot of oil on my floor
I went back to the dealer and said no leak..
but its still leaking ,very small leak ,when car sits for long time
I,m going to a different dealer this week
they probly did not put the gasget on right
or????
Old Oct 8, 2006 | 05:57 PM
fortified's Avatar
Could be either the filter or drain plug gasket. If the bottom cover is off, you should be able to see which it is.
IF it is the filter, they either overtightened it, or left the old O ring on, or the new O ring is not seated. (IDIOTS!) Lastly, some old oil that was drained ran along some chassis parts and is now dripping out because they did not clean up after themselves.
You should definitely go back and have them make it right. NO EXCUSES accepted!
Old Oct 8, 2006 | 06:01 PM
6969g35's Avatar
thanks for infor..
glendale has the wost sevice
my car never leak oil
Old Oct 8, 2006 | 06:20 PM
TURBOTOM's Avatar
a.k.a kleicoupe
mabe the dipstick is loose???
Old Oct 8, 2006 | 06:55 PM
Msedanman's Avatar
O.F. Administrator
or????
Could it be that they changed your oil with the engine cover left on and spilled oil on it while doing the change?????
By all means, make sure the drain plug and filter are tight, but don't I wouldn't be surprised to learn that they left the cover on...
C.
Old Oct 8, 2006 | 07:03 PM
gary c's Avatar
Leaks are soooo fun...............!
I'd start with the cover. Make sure it's not floating
with oil......then check the wonderful dipstick making
sure it's all the way in. With the cover off you'll be
able to see where the leak is.......filter or drain plug.
I purchased my G from Glendale Infiniti but I haven't
been back since.......and won't!
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
