G35 & G37, Coupes & Sedans
HELP! VDC, ABS, slip light on... will not let me out of park
Old Dec 8, 2006 | 04:23 PM
stpdevil's Avatar
Ok so I went to get into my car... I turned it on, everything normal, hit the brakes, and tired to put it in gear, but it would not go into gear and the ABS, VDC, and slip lights all turned on and stayed on. So I turned it off and tired again, and sure enough, when I hit the brakes, all the lights turn on and it will not let me out of park. Normally, when you hit the brakes you can hear the shift lock click off... it does not make this sound anymore. If I use the manual shift lock I can get out of park and drive the car... but i dont know what the problem is
Old Dec 8, 2006 | 04:47 PM
SFLG35's Avatar
FGC President
sounds like your brake fluid might be low
stpdevil's Avatar
blown brake light fuse... everything is good now
Old Dec 9, 2006 | 01:07 PM
GreenGoblin's Avatar
The goblin resurrection
huh that is crazy
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
