G35 & G37, Coupes & Sedans
Apexi Safc S-afc Can It Be Installed In The G35?
Old Dec 23, 2006 | 11:33 AM
clifftrail's Avatar
I don't think it was meant to be, thats a good time for minimal mods on the G.
Old Dec 23, 2006 | 11:53 AM
Nismo G's Avatar
https://g35driver.com/forums/drag/126478-new-time-slips-11-16-06-a.html
there are my time slips. They are great times for the mods i have i do agree. Its just because im awesome!
Old Dec 23, 2006 | 02:57 PM
Mark350GT's Avatar
it will work fine, but only for use with NA mods
Old Dec 23, 2006 | 08:53 PM
j-velocity's Avatar
Originally Posted by Nismo G
was that sarcasm...?
I really think it's nice to run high 13 with just exhaust, intake and spacer since a stock car is consider as mid 14s...
Old Dec 23, 2006 | 09:04 PM
j-velocity's Avatar
Not all widebands have a datalogging capability and its too hard and dangerous to try and tune it at WOT while driving. So do and internet search for wideband controllers and several will appear. Then just read and find out which one works for you. They all do the same thing, some just have different features.
Sorry but I have to ask this dumb question..
So SAFC is a wideband controllers too?
thx
Old Dec 24, 2006 | 09:24 AM
clifftrail's Avatar
Not a dumb question, no SAFC taps into the fuel and helps you adjust it up or down to get it to a desired range. A wideband is a completly different device that will tell you what your A/F ratio is at an given RPM.
A wideband look similiar to a stock O2 sensor with some sort of gauge device attached that will display what your A/F ratio is at any given RPM while driving. Then you use the SAFC to adjust your fuel +/- to give yourself the max hp.
Old Dec 24, 2006 | 08:02 PM
j-velocity's Avatar
Thx a lot for your help.....
I am really appreciated...
Old Dec 27, 2006 | 07:39 PM
infinitialex's Avatar
Nismo can you please post your S-afc setting just for general referances ,, I jsut want to see how much corection they have done....
Old Dec 27, 2006 | 07:41 PM
mr freeze's Avatar
yes can you please post..im also interested as i'm going to install mine this weekend
Old Dec 27, 2006 | 07:43 PM
now just so all you know. You can not take someones setting and set them on your car as each car will very a lot even with the exact same setup. So do not atempt to use somones settings this could result in engine damage.
Old Dec 27, 2006 | 09:28 PM
Calvin's Avatar
Overglorified Altima
yep. all cars react differently to mods. even the same mods. some cars even run lean and others run rich from the factory. everything is different -.-
Old Dec 28, 2006 | 04:46 AM
somone please post ur S-AfC setting.........
Old Dec 28, 2006 | 11:57 AM
DaveB's Avatar
The VQ35 Maxima and Altima guys have been running S-AFCs for years and are seeing 10-15whp gains. The only thing I don't like about the S-AFC is that you have to cut into the wiring harness.
Jusseth
Sep 13, 2020 12:25 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
netcbc
Engine - Intake/Fuel CDN
Jul 24, 2015 02:21 PM
