14,000 mile checkup
Rediculous
I was quoted over $400 when I brought my G to the dealer for 15K service. I asked them what for... After explaining that I know what needs to be done and that there is no way it has to be this much, I negotiated it down to $175. Still a rip-off, but at least I got a loaner.
Seriously. Infiniti called me up and said I was due for that. I asked what they did exactly and they couldn't tell me. I believe at 14K it's just a bunch of inspections, oil and cabin filter change. Definitely not worth $350.
The following information is provided to give you, an Infiniti owner, a better understanding of the scheduled maintenance items that should be regularly checked or replaced.
15,000 Miles or 12 Months
PM : Premium Maintenance
S1 : Schedule 1 Maintenance
S2 : Schedule 2 Maintenance
Replace PM S1 S2
Replace engine oil and filter • • •
Replace in-cabin microfilter • • •
Lubricate all locks/hinges •
Road test vehicle
Replace automatic transmission fluid
Replace climate-controlled seat filters
Replace differential oil (except I35)
Replace engine air filter •
Replace engine coolant/flush system
Replace engine drive belts
Replace manual transmission oil
Replace radiator cap
Replace radiator hoses
Replace spark plugs
Replace transfer case oil (AWD FX35/45, G35x)
Replace wiper blades •
Rotate tires (except G35 coupe) • • •
Optional: flush automatic transmission
Inspect PM S1 S2
Air conditioning system •
All lights •
Automatic transmission fluid • • •
Axle & suspension parts • •
Battery fluid level/terminals
Brake lines & cables • • •
Brake fluid level
Brake calipers, pads, rotors • • •
Charging/Starting system
Clutch fluid
Cruise control vacuum hoses • • •
Coolant level/top-off
Differential oil (except I35) • • •
Drive shaft boots • • •
Engine air filter
Engine drive belts •
Exhaust system • •
Front suspension ball joints • •
Fuel lines / connections
Fuel tank vapor vent system hoses
Headlights / adjust if necessary
Horn operation
Manual transmission oil • • •
Power steering fluid/top-off
Propeller shaft (except I35) • • •
Radiator hoses
Shock absorbers/struts
Steering gear and linkage • •
Steering linkage ball joints • •
Tires/adjust air pressure
Transmission fluid/oil
Transfer case oil (AWD FX35/45, G35x) • • •
Washer fluid level/top-off
Wiper blades
Replace PM S1 S2
Road test vehicle
Replace spark plugs
Inspect PM S1 S2
All lights •
Brake fluid level
Clutch fluid
Engine air filter
Exhaust system • •
Horn operation
Radiator hoses
Wiper blades
$350 does sound ridiculous to me, but at the same time I still want to be on the record of having some maintenance done in the event that I have to get some warranty work in the future (or just sell the car). In any case, I will be taking it in tomorrow for the checkup. And signing over my wallet, apparently.
Don't let them bully you into this. Just because you do not get maintenance from the dealership will not void your warranty. Just keep careful records of your oil changes and other maintenance done and you will be fine.
why do we even need one at 14,000 miles ?
why do pay so much for this dam car and have to keep getting checks like this? wtf?
**** i am not going for a check up intill my car hits 60,000 ...
i have no money
i have no money
i never did a checkup on my car, just regular oil change, had 32k miles on my car when i traded it in and had no problems with the car at all except for the headunit, damn speaker cutting off. $35,000 car and i had to listen to FM radio.
