G35 & G37, Coupes & Sedans
Our cars oly have a 15 gallon tank. rant.
Old Mar 8, 2007 | 10:04 PM
BadBoy06's Avatar
Originally Posted by madscientist
Sure Sure I know it holds 20 gallons, but when the light comes on 3/4 of the way through you know you better get it filled up because the next person that gets in there with you is going to point out the fact that you need gas. It's also annoying to drive with that big yellow light on and so I get mine filled up when I get to the quarter tank mark whether the light is on or not.
Is there a way to fix this so that the light comes on when there's about 2 gallons left? I actually ran out of gas once because I was on the expressway driving from Atlanta, GA to Charleston, SC and forgot how long the light had been on and what my mileage was when it did come on. I knew I had about 4-5 gallons when the light came on, which roughly translates to 80-100 miles. I was so hung-over that before i knew it my engine stopped, clutch started burning, and i was on the side of the road screaming to infiniti roadside assistance about how inaccurate the gage was.
anyone else hate this thing about our cars?
I've always gassed up when I'm down to a 1/4 tank..works for me
Old Mar 9, 2007 | 02:12 AM
Hitman_'s Avatar
easiest way to remember or find out how much is left on the tank, look at the fuel gauge before you start the car.
Old Mar 9, 2007 | 09:02 AM
VinNYCG's Avatar
G SQUAD
Thats definitely the right way to do it.
-Vin
Old Mar 9, 2007 | 09:39 AM
tekknikal's Avatar
when my gas needle hits the bottom of E, i think i have 4 gallons left.
at 1/4 tank, i probably have 10 gallons lol.
i wish infiniti would address this. the bottom of E should be more like 2 gallons and the gauge should more more progressively toward it.
Old Mar 9, 2007 | 10:24 AM
Potty_Pants's Avatar
you really shouldnt run the tank down to a gallon or less... the sediment will cause unecessary wear.
now wether this topic is warranted or not "what is saved". myself I'll fill up when the light comes on , with that being said... if you wait for the light to come on and use up the reserve 3-4 gallons . YES YOU WILL EVENTUALLY SKIP A GAS STATION RUN. consuming an extra 2 gallons after the light is on will allow you to skip a gas station run around every 8th time. I fill up once every three weeks so i really dont care.
ppp
Old Mar 9, 2007 | 10:33 AM
afr0puff's Avatar
Supa Dupa Moderator
While we may have a 20 gallon tank, you can only fill up about 17 gallons. This is an engineering trait of all gas tanks. 2-3 gallons are purposely left "unfulfillable" to allow for back pressure of when gases evaporate.
Old Mar 9, 2007 | 12:56 PM
accordfreak's Avatar
I think the most I've filled up is around 19.4 gallons hehe
Old Mar 9, 2007 | 01:11 PM
AaronKalb's Avatar
Pull the bulb if it bothers you so much.
Old Mar 9, 2007 | 03:14 PM
madscientist's Avatar
ditto, i got 19.5 before.
Old Mar 9, 2007 | 03:18 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
lmfao, the light is there for a reason pal, this is a performance car... if there's any one car you dont want to run all the way to empty, its a performance car. If you do it to often then you'll jack up your fuel pump and that's a pretty penny to replace. So it would make sense to fill up the tank when it still has 3-4 gallons in the tank just to be on the safe side. You know what they always say "better safe than sorry"
-GP-
Old Mar 9, 2007 | 07:20 PM
dudeimjohn's Avatar
i just wait til the needle is on the E...
Old Mar 9, 2007 | 07:22 PM
SFLG35's Avatar
FGC President
everytime i fill up i put in like 16 17 gallons, and i only get like 285 miles to a tank
Old Mar 9, 2007 | 08:07 PM
Andy2434's Avatar
Works for me, as well. Have never seen the light come on in almost 2 years.
Old Mar 12, 2007 | 01:27 PM
csdstudio's Avatar
My light comes on just below the second line nearest E. At that point I stop and put in about 18 gallons. Sheesh, if the light didn't come on early enough you'd rant on and on how this car sucks because you ran out of gas on the interstate lol. And then you'd beatch some more when the fill wiper fluid light comes on too soon.
Old Mar 12, 2007 | 01:46 PM
  #30
jascastan's Avatar
I have the NAVI in my car tell me how many more miles I have before I have to get gas. I usually don't any longer than when I have 60 miles left.
