G35 & G37, Coupes & Sedans
Prediction: 2008 sedan will definitely have the 3.7L engine
Old Mar 20, 2007 | 09:10 PM
LudwigB's Avatar
After reading about the new G37 coupe, it turns out that the 3.7 is not merely a "bore out" version of the 3.5 engine (actually the stroke was lengthened by 5mm). It's valve electronic is completely different. Unless Nissan decides to price the coupe much more than the sedan, I feel that the new sedan will almost definitely have the 3.7L engine.
Old Mar 21, 2007 | 04:29 AM
kca2000's Avatar
Ill tell you right now, if its true, im never buying a first year car again. I never expected infiniti to replace an engine that has brought them so much recognition a year after re freshening it. Doing that will also make this engine "scarce" in the market so after market parts will probably be limited too. Damn, this could really suck..
Old Mar 21, 2007 | 06:09 AM
KDG35's Avatar
I guess this leaked out before expected!! G37 Video and Pics!!
http://www.automobilemag.com/multime...iti_g37_coupe/
Old Mar 21, 2007 | 07:30 AM
Railgunner's Avatar
Sedan needs a new transmission... 6 or 7AT.
If they do that, i'll be trading on a 2008.
Old Mar 21, 2007 | 08:33 AM
goingtopless1's Avatar
was anyone impressed by the 08 coupe?
Old Mar 21, 2007 | 08:38 AM
moose1963's Avatar
I agree that they need at least a 6 speed AT. However, I'm not convinced they will (or need to) put the 3.7 into the sedan. They need to differentiate the coupe from the sedan. The coupe should have a lot more performance than the sedan. From reading a lot of threads here from people who have owned both, there doesn't seem top be that much difference between the two. Just my opinion.
Old Mar 21, 2007 | 08:51 AM
dcmidnight's Avatar
+1. I'm not sure they need to insist that the same engine be standard in both the sedan and coupe. I've driven/commuted/roadtripped with this car for 3 months and have zero complaints about the engine.
Old Mar 21, 2007 | 09:01 AM
SilverII's Avatar
thanks for the link.... I am a little underwhelmed
Old Mar 21, 2007 | 09:10 AM
tiblot's Avatar
thats bc its FUGLY
Old Mar 21, 2007 | 12:23 PM
excluesiveonez's Avatar
im glad they didnt change it too much from the current version
Old Mar 21, 2007 | 12:55 PM
swordfish's Avatar
that is why I do 2 year leases.. they always come out with a better one
Old Mar 23, 2007 | 09:08 AM
slo poke's Avatar
It looks almost exactly like the 2008 altima coupe to me. The concept looked much better. I am def. feeling better about going with the 07 sedan.
Old Mar 23, 2007 | 10:28 AM
sloppymax's Avatar
i saw confirmation that the 08 coupe was going to be just under 3700. if they can put the same power in the sedan without adding all the weight (close to 300lbs to the coupe) then ill take a look at it.
Old Mar 23, 2007 | 10:32 AM
Garnet Canuck's Avatar
Traveling Administrator
Keep this on topic guys, this thread isn't about how the 08 Coupe looks.
Old Mar 23, 2007 | 02:20 PM
Skaterbasist's Avatar
Retired SuperMod
Ehhh.
You people need to stop exagerating.
On topic, yes I believe the Sedan will have a 3.7 as an option. Theres a 335i Coupe and Sedan, so making a 3.7 liter only available for the coupe does not make any sense at all.
