G35 & G37, Coupes & Sedans
What's the name of that "Mod" law.
Old Mar 30, 2007 | 06:58 PM
6MTzer's Avatar
Can somebody tell me the name of the law that states that a dealer has to prove that a engine modification affected the engine?
The dealer is keeping my coupe over the weekend because they can not figure out why my "check engine light" is on and the car is idling rough.
In every conversation, they keep bringing up the spacer I used to have on the car like it is the root of everything that has gone wrong.
Thanks.
Old Mar 30, 2007 | 07:00 PM
Jeff92se's Avatar
Red Card Crew
http://www.granatellimotorsports.com/magnusonmoss.htm
I swear the dealer techs are numnutzs. BUT if you unplugged the TB connector, then indirectly they might be right. But it's hard to comment when you don't specify what code you threw
Old Mar 30, 2007 | 07:34 PM
6MTzer's Avatar
Thanks for the fast reply!
We ran the code at a local speed shop and the only thing that came up was "random misfire."
The dealer is saying that "One of the banks is not working right" ?
I explained to them that the spacer has been off for five months now and is in no way related. Still they love to keep bringing it up.
"The problem seems to be in the area that you had the spacer."
Old Mar 30, 2007 | 07:37 PM
Jeff92se's Avatar
Red Card Crew
They might be able to ding you if you installed the upper plenum wrong. ie.. a vacuum leak might cause an erratic idle and a random misfire if one cylinder gets too much unmetered air (ie.. a vacuum leak will allow unmetered air [air not measured by the maf] to get sucked into the engine and will give the ecu a hard time.
Old Mar 30, 2007 | 07:53 PM
6MTzer's Avatar
I am just hoping for the best now. I had the spacer installed at the speed shop. They specialize in G's and Z's. So I am pretty sure it was installed correctly.
Old Apr 2, 2007 | 03:00 PM
6MTzer's Avatar
The dealer just called and the problem turned out to be a bad fuel injector.
Nothing to do with the plenum
Hopefully this is what was causing the pinging in the low RPM's also.
Old Apr 2, 2007 | 03:03 PM
Hi-TechG35's Avatar
What a bunch of idiots the dealer does anything to get out of fixing problems that has nothing to do with mods.
Old Apr 2, 2007 | 07:17 PM
Rphillips6487's Avatar
Thanks.
hey there, I have had the problem with my car idling, does the engine run fine and then suddly cut out and almost stall but pick itself back up and run again?
as for the chech engine light, mine never went on but not it is after almost evrry light is on since i lowered my car with spc a-arms
Old Apr 2, 2007 | 07:45 PM
6MTzer's Avatar
Originally Posted by Rphillips6487
hey there, I have had the problem with my car idling, does the engine run fine and then suddenly cut out and almost stall but pick itself back up and run again?
as for the check engine light, mine never went on but not it is after almost every light is on since i lowered my car with spc a-arms
No, my symptoms were the light came on and the car started vibrating. I could watch the stick shift go back and fourth when idling.
The weird thing was, it still seemed to run fine. I think their theory of one bank not working was bull.
Have you checked for any vacuum leaks?
Old Apr 2, 2007 | 08:45 PM
GreenGoblin's Avatar
The goblin resurrection
well that it good that it got fixed but ya they seem to try to find any reason for you to have to pay
Old Apr 2, 2007 | 09:00 PM
6MTzer's Avatar
Yes, I thought for sure they were going to blame the spacer for everything. I was very relieved when they said "No charge."
Old Apr 2, 2007 | 09:09 PM
I havent put im going to be dropping off my car soon and all should be well after that.. (crosses fingers)
Old Apr 15, 2007 | 11:19 AM
VipDesigns's Avatar
I am having this same issue that Rphillips6487 is having. It only happens once in a while. I have no mods an its an 03 / 30k miles.
Old Apr 15, 2007 | 11:31 AM
gary c's Avatar
Mods vs Stealership
I'm sure they we're disappointed the tech couldn't find something to charge
you for........glad they located the injector issue.
