G35 & G37, Coupes & Sedans
G35 Jack-up Points?
Old Apr 3, 2007 | 06:47 PM
kevinn's Avatar
G35 Jack-up Points?
I've searched and searched and have not found a direct answer. Can anyone just post a pic of the underboy of a g35 or tell me where the jackpoints are? I'm chagning my oil and would like to know where i can jack it up using a floor jack. thanks!
Old Apr 3, 2007 | 06:58 PM
redlude97's Avatar
Look in your manual, the recommended jackpoints are in there
Old Apr 3, 2007 | 07:00 PM
gary c's Avatar
The what...........?
Generally speaking if you need to know something about your new car it's
always in the owners manual.......knowledge is power!
Old Apr 3, 2007 | 07:01 PM
kevinn's Avatar
I looked in the owners manual. coudlnt find it, ill try again.
G35 Mass's Avatar
Old Apr 3, 2007 | 07:03 PM
kevinn's Avatar
I've seen that picture. Isn't that for the 350z?
thank you g35mass.
Shall I jack the car in the center like it says?
Old Apr 3, 2007 | 07:05 PM
Mike_Deezy's Avatar
Not sure if it's a picture of a 350z, but those are the jack points that I use to jack up my car.
Old Apr 3, 2007 | 07:07 PM
bythabay's Avatar
thank you g35mass.
great discussion of all details here:
https://g35driver.com/forums/showthr...=135852&page=2
Old Apr 3, 2007 | 07:14 PM
kevinn's Avatar
Do any of you use regular floor jacks to lift the g35?
Old Apr 3, 2007 | 07:28 PM
RandomHer0's Avatar
I have a low profile jack and I use the frame rails.
Old Apr 3, 2007 | 08:08 PM
Aznteazer's Avatar
doesn't that bend the frame rails?
Old Apr 3, 2007 | 08:31 PM
maj83's Avatar
lazy a$$
I like using ramps instead of jacking it up
Old Apr 4, 2007 | 12:15 AM
kevinn's Avatar
Yes, I've decided to go with ramps as well. It looks a lot safer to me. I'll be changing my oil tomorrow morning with 5 quarts of pennzoil 5W-30.
Old Apr 4, 2007 | 01:04 AM
G35 Mass's Avatar
That picture is from a g35 service manual.
I used to jack up one corner of the car, put it on a jack-stand, then put the jack under the center point. Now I just drive my car onto 2-2x4's, and I can get the jack under there.
Old Apr 4, 2007 | 12:42 PM
Espresso's Avatar
You can use the stock jack to do an oil change. Just be sure to use jack stands while you're under the car. Ramps are just too hard to get the car on, especially a manual car. My main fear with ramps is driving too far only to go slamming down the other end of the ramp. Plus, using a jack allows you to lower the car while the oil drains to get all of it out. If your ramps aren't level to begin with, how do you plan to move the car without oil in the engine?
