G35 & G37, Coupes & Sedans
Help: Heated Seat question...
Old Apr 5, 2007 | 02:49 PM
kryptkicker's Avatar
Just purchased an '03 Coupe for the wife. We noticed that the heated seat buttons don't light up, nor do the seats heat up. I figured it would be just a fuse, but after pulling some fuses under the dash, I have yet to find one that is burnt out. Am I missing something....?
Please help
Old Apr 6, 2007 | 09:19 AM
bump....
Old Apr 6, 2007 | 09:37 AM
Hi-TechG35's Avatar
Sounds like you might have an electrical problem. Are you still under warranty? If so take it back to the dealer.
Old Apr 6, 2007 | 09:40 AM
Forgot to mention, out of warrantee... Didn't know if the fuse was under the hood or in the car... could it also be the switches?
Old Apr 6, 2007 | 09:49 AM
Hi-TechG35's Avatar
How long ago did you purchase the car? The car should have a 90 day warranty .Check to see if the seat is grounded also. I know that I bumped the plastic cover on my passenger seat taking something out and knocked the ground wire loose causing loss of my passenger power seat. I just popped the cover off and re-connected it back and everything worked again.
Old Apr 6, 2007 | 04:26 PM
Curt G's Avatar
Also, check the fuses by the battery in the engine compartment. You have to remove that plastic cover to get to them.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
hrdwirk1
Oct 2, 2015 06:34 PM
doakley92
Sep 25, 2015 12:58 PM
