G35 & G37, Coupes & Sedans
Trouble Fueling my G
Old Apr 20, 2007 | 06:00 PM
patrickwong's Avatar
So, i'm having trouble fueling my coupe. The damn gas pump keeps popping like the tank is full. It won't engage and keep pumping. Anyone know why it does this?
Old Apr 20, 2007 | 06:06 PM
binar's Avatar
There is a 'Fuel Filler Hose Recall' that helps. However, a quick way around it... turn the fuel nozzle 90 degrees. It works for me when my car is being temperamental.
Old Apr 20, 2007 | 06:19 PM
I don't know if this is the reason....
But, my car has been sitting in my garage on a low gas tank for close to a month. Does that affect it?
Also, what does the 'Fuel Filler Hose Recall' do? How do i know if i need it?
Old Apr 20, 2007 | 06:36 PM
Tjeh's Avatar
When I first bought mine it did that... I was like 'WTF I NEED THIS GAS PLAZE' ... But now I don't have a problem at all, heh. Weird.
Old Apr 20, 2007 | 06:43 PM
glennp_1999's Avatar
Call the dealer and see if your car is part of the recall on the fuel hose. I brought mine in for a totally different problem when I picked up my car they said they also replaced the feul hose. Don't leave your tank empty when storing the car for that long fill it up and put Stabil to keep the fuel fresh inside the tank. Nothing worse than bad fuel inside your car. Goodluck I hope you fix the problem.
Old Apr 20, 2007 | 06:49 PM
GISMO35's Avatar
Did you try a different pump? I've had that problem when the pump was not working properly.
Old Apr 20, 2007 | 06:59 PM
LjN_728's Avatar
Will the gas pump if you manually push back vapor boot? You know...like when you fill up those gasoline jugs.
Old Apr 20, 2007 | 07:07 PM
Ya, i even tried another pump. And still the same problem.
Why is it bad to leave the car on empty when in storage? The dealership does that when it's sitting at their showroom.
Old Apr 20, 2007 | 07:10 PM
oscottio's Avatar
i've had the valve replaced and it still did it later. they changed some sensor this last time around. so we'll see. so far so good, but i notice its at certain pumps. haven't tried those pumps since the last fix.
Old Apr 20, 2007 | 07:12 PM
Andy2434's Avatar
I had the exact same issue as you do when I first got my G. I got it fixed via the following TSB. I trust this will cure your issue, as well. Good luck and let us know how it went.
http://www.infinitihelp.com/Ownershi.../ITB05-031.htm
Damn, luckly I wasn't on empty....
I actually i was on Empty, but i was able to get like $10 worth of gas.
Old Apr 20, 2007 | 07:43 PM
nghiars's Avatar
its a TSB issue.. the fuel hose needs to be replaced.; recall so no charge... call the dealer and make sure it hasnt been done and schedule an appt to do it.
Old Apr 20, 2007 | 07:48 PM
GR8TG35's Avatar
Fuel hose recall is another issue entirely...
There is a valve in the filler neck to prevent pressure build up....thats what is giving you the trouble.....some stations pump pressure is higher than others.... Take it to the dealer...they should replace the valve.
This was a major issue back in 03-04-05....
Old Apr 25, 2007 | 03:49 AM
namrock's Avatar
i had the same problem too but only when its raining.....
Old Apr 29, 2007 | 01:10 PM
Pivo's Avatar
just fill the car up at shell or mobile stations and you wont have a problem. those are the only stations i can use, any other stations just give me few gallons and it stops.
