5AT downshifting by just moving lever?
This happen to anyone else's G? On the freeway the other day at 70 put it over into manual mode just for kicks. Was surprised when the dashboard readout said '4', and could hear the engine rev up. Back to auto, and tried it again, while watching the RPM's. Sure enough, they jumped up a couple of thou. My question: is this normal? I mean, you'd think it would stay in the same gear when moving the gear shift to the manual side. Why should it downshift on its own? Can't tell if it does it at lower speed, 'cause one doesn't know what gear the trans is in, while at 70 safe to assume in 5th.
yes it's normal... at least to the extent that my car does it too... Never tied it at supper high mph though (140ish)... but for normal freeway driving 70, 80, 90 whatever, you will be fine. I use it all the time as a quicker passing gear than letting it downshift automatically… damn I’d wreck if I waited for full auto to get me out of a pickle…
I'm curious now though at real high rmp (like I said 140ish mph in 5th I think is 6K rmp or so) what would happen... I'm not gonna try it to find out, but I'm curious...
It is normal. When you're in 5th gear and kick it into manual mode, the tranny is programmed to downshift into 4th. In lower gears in auto mode, the tranny won't downshift. It'll keep you in the same gear when you switch over.
Originally Posted by g035sedan
would you still be able to UPshift to 5th gear in the manual mode?
so it'll always know what gear you're in and downshift to the NEXT lower gear when you engage into manual. very nice. and you can also upshift all the way to 5th in manual.
Originally Posted by g35sedan5at
when ur going 140 i dont recall wat the rpm's are in 5th, cuz honestly i was too fukin scared to take my eyes off the road for one millisecond. but its pretty high up there
my AT on flat straight surface was around 6Krmp at 140mph is I recall correctly. (this was in the middle of the desert with ZERO traffic)... instead of everyone posting rmp at 140 does anyone know the answer to the question though?... What happens if you went MM from full auto at that speed? Would it go to 4th like normal?
Originally Posted by excluesiveonez
no bc it has no rpm's left in 4th
