G35 & G37, Coupes & Sedans
would 0w-40 mobil 1 be a good oil for the 3.5
Old May 21, 2007 | 06:50 PM
flash gordon's Avatar
it is the only "true" synthetic on the market and is the only oil OTC that I can find that is recommeded for BMW, VW(audi), Mercedes AMG.......can the 3.5 use the same oil?
Old May 21, 2007 | 06:55 PM
Jeff92se's Avatar
Red Card Crew
While I "think" the 0w-40 is still a group IV, that's a BIG viscosity range for an oil to handle.
I'd MUCH rather use something like Amsoil in the proper viscosity range if you want to use a "100% synthetic" group IV type oil. I think there still a few other 100% oils out there.
Old May 21, 2007 | 08:33 PM
jdmeg21's Avatar
thats the wrong viscosity for our cars. use amsoil or the German Castrol 0w30
Old May 21, 2007 | 09:33 PM
ttrank's Avatar
Grocery getter
Might not be the best but I also run 15w50 which seems to work just fine.
Old May 22, 2007 | 01:39 PM
robchris's Avatar
So if we are to order the amsoil what weight or the manufactuerer do we order?
Old May 22, 2007 | 03:48 PM
bocatrip's Avatar
I use 0W/40 Mobile1 in my G35 here in Florida. I would not use the 5w/30 as that multigrade is way too thin. Here in the extreme heat this weight is the way to go. I believe that the German castrol 0W/30 is a very thick oil as well. That oil is heavier than other 0W/30 synthetics. It is actually very close in thickness to the 0W/40 Mobile1. Both German Castrol 0W/30 and Mobile1 0W/40 are really equivalent to a "0W/35" if there was one. Some other synthetic oils are also good, but I like to go with what is accessible and easier to find. It's expensive, but it's worth it.
Old May 22, 2007 | 04:17 PM
bocatrip's Avatar
It's important to know the exact temperature that oil encounters at the bearings. The sump temperature is usually 10-25 F lower, depending on rpm and load.
A 30 might be 28 and a 40 might be 35 where it counts.
The owner should select the top viscosity based on extreme hot idle oil pressure.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
derres
Aug 28, 2015 03:27 PM
bjo16
Aug 4, 2015 09:52 AM
