G35 & G37, Coupes & Sedans
Oil Change ?
Old Jun 7, 2007 | 10:11 AM
watsgoodG's Avatar
Oil Change ?
If i don't change my oil every 3 months will this void my warranty? I use my car only on the weekends and put about 1,000 miles in 3 months. Should i be changing at 3,000 miles or every 3 months. I use regular oil from the dealer not synthetic.
Old Jun 7, 2007 | 10:49 AM
darnelled's Avatar
3,000 miles is what matters.
Old Jun 8, 2007 | 02:15 AM
vjquan's Avatar
Yup, just change it at 3K. Every 9 months is perfectly fine.
Old Jun 8, 2007 | 07:45 AM
kevink's Avatar
With my pickup, which gets about 4K/year, I just do it about every 6 months.
Drive it on the highway every now and then to help keep moisture from building up in the engine oil, and you should be safe.
Old Jun 8, 2007 | 08:27 AM
SilverII's Avatar
5K for me!
Old Jun 8, 2007 | 03:03 PM
MightyMouse's Avatar
too bad for you, because you're not taking advantage of Infiniti's engine replacement program. ..
You get a new engine every 3000 miles under typical driving conditions with the 06 6mt..
Old Jun 13, 2007 | 11:57 AM
watsgoodG's Avatar
i think im going to switch to synthetic...im soooo pissed im not sure if this is normal i check my oil and it seems to be 1/8 of an inch from the full line...im assuming with all the oil consumtion issues this isnt really a problem
Old Jun 13, 2007 | 08:25 PM
JABG35x2's Avatar
I think that this is normal. When car was new and three subsequent changes from the dealer have all registered slightly below the full mark on the stick. Believe I saw a post a while back that also mentioned this.
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
