G35 & G37, Coupes & Sedans
drift
Old Aug 5, 2007 | 03:39 AM
acside's Avatar
drift
Is the g35 coupe a good car to attempt drifting in while it is stock. i want to start learning how to drift and i don't know if i should attempt it stock in a g.
Old Aug 5, 2007 | 03:44 AM
drunkin master's Avatar
You can drift in any rwd car.
Just be safe about it, it would help if you have a manual too.
I know of a class/school up north in California where you can learn but would need to bring your own car. I have heard they offer great classes and have experienced drivers.
Old Aug 5, 2007 | 02:28 PM
OCG35's Avatar
I would buy an old beater to learn how to drift... Unless your G is your beater
Old Aug 5, 2007 | 02:47 PM
SDGeneralCounsel's Avatar
+1. Parts for the G are fairly expensive and when you are drifting you will be breaking parts left and right. You would need the 6MT G, a good LSD, and a decent set of coil overs and break pads to start with to be safe. Also, have tons of money for tires, parts, and you would need a second car for when your G is down.
Old Aug 5, 2007 | 02:54 PM
MIA BlazinVQ's Avatar
brb getting cut
do you mean you'll be breaking parts after the FIRST drift u do, or is it only if you regularly drift on a daily basis? also, what parts would u be breaking?
Old Aug 6, 2007 | 11:19 AM
Klubbheads's Avatar
I am happy with the stock LSD as far as drifting goes. It is very easy to keep the car sliding in control for good 10 seconds.
To the OP, go to a empty parking lot in the rain and start going into circles in slow speeds and gradually increase the speed to see how the car behaves. Whenever u are able to control a slide in the rain then u have past the test. It is very easy to do it in dry after doing it in wet ground. It does take time, patience and calmness to go sideways.
Old Aug 6, 2007 | 06:10 PM
acside's Avatar
thanks for the help
Old Sep 25, 2007 | 07:50 AM
stasikg35's Avatar
did a few doughnuts today and drifted a few times really the only thing i messed up was my tires but not a lot. another thing you can break is your motor from having the rpms jump other than that nto really alot you can mess up
Old Sep 25, 2007 | 08:27 AM
pjames's Avatar
spend a winter in canada, get some good snow tires, and have some fun, then move up to pavement. (i alway suck at drifting modes in racing games... my "keep the car straight" instinct is too strong, all but one of my winters driving have been in rwd cars, with nowhere the weight distribution of the g.)
i would suggest a beater rwd drive car, an old vic or something, add a power adder, for a lot less than the price of a G, and weighs about the same (get an aero (92-97) if you can, lighter), and more importantly, can take hits from the walls quite well. you don't want to be distorting a G.
Old Sep 25, 2007 | 06:42 PM
Beebo's Avatar
I agree then move on to the G
rezendvous420
May 31, 2020 01:26 PM
brycealbr
Sep 17, 2015 12:56 PM
