G35 & G37, Coupes & Sedans
Weird Issue with Gas Gauge...
Old Aug 6, 2007 | 10:53 PM
g8tor20's Avatar
FGC's official flip flopper
Okay....was driving on the highway when all of a sudden my gas gauge goes from half tank to dead empty. I flipped on the nav screen to the fuel economy section and it first displayd 89 miles to empty and then 5 and then ****. I was over 20 miles to the nearest exit or service plaza. I ended up drafting a semi at like 55 to see how far I could go (thinking maybe a fuel hose broke or something similar).
I got to the servie plaza and filled up with only 10 gallons of gas meaning the gauge was wrong and I still did in fact have half a tank in there. (I did check for leaks or traces of gas everywhere).
So, I am guessing it was a computer glitch. Anyone have this problem before? After the fill up and restart, everything seems to be normal again. I had no idea the gas gauge was electronic....still thought we had the whole bobber thing. lol
Anyways, anyone have any expeience with this?
Thanks
Jason
Old Aug 6, 2007 | 11:00 PM
express705's Avatar
no.. never had that.. but the gas guages are a bit shakey in these cars..
Old Aug 6, 2007 | 11:37 PM
snarlynx's Avatar
Yeah, the gas gauge is weird in these things. It always looks like I use a lot fast and then the last half seems to last forever... the opposite of most cars.
Old Aug 6, 2007 | 11:55 PM
GreenGoblin's Avatar
The goblin resurrection
I never had an issue like that but it is kinda notchy like it will go down fast then slow
Old Aug 7, 2007 | 08:11 AM
express705's Avatar
whenever i drive, the needle doesnt move, but when i shut the car off and start it up again it goes down quite a bit.
Old Aug 7, 2007 | 09:33 PM
Blue Lion's Avatar
1997-2004 Corvettes are common with this. My 2000 had this issue. It's the fuel sensors in those cars, 2 per car. My extended warranty covered my repair. Try Techron additive, and Chevron gas on top of that. It helped many of the Vette owners, but not me.
Old Aug 8, 2007 | 03:39 PM
DFaz's Avatar
I have never had that problem, however something similiar. My gas gauge would show only half of what was in the tank. This lead to a few fill ups where I thought I would take 15 or so gallons when it would only take 8-10. I brought it to Infiniti and turns out it was a bad fuel sensor. Thus reading the incorrect fuel limit. I had it replaced and everything is fine. I have an 03 Coupe. Something you might want to check into.
Old Aug 8, 2007 | 03:56 PM
Drtybrd61's Avatar
sounds similar to my problem. i ended up having to have the gas tank replaced.
Old Aug 8, 2007 | 04:07 PM
DaveG@Altered's Avatar
Have you done any fuel upgrades that would requier you taking out the fuel sending unit?
Old Aug 9, 2007 | 01:57 AM
Ventural's Avatar
Florida G35 Club Charter Member
One of your two fuel sensors is not working which was a common problem for earlier G35's. Your dealer will replace your entire fuel tank under warranty.
Old Aug 9, 2007 | 01:23 PM
03SilverGeee's Avatar
This happened to my car ('03 coupe) when I first bought it (used). It turned out that there is a sensor in the fuel filler neck, which is connected to the gas tank, that was bad. The dealership had to replace the entire fuel neck and gas tank (under warranty). They said that it was a common problem and only took a day to get it fixed. Good luck!
mtlruss
Dec 20, 2015 01:51 PM
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
leo38cheng
Nov 12, 2015 06:49 PM
MsFitFern
Sep 7, 2015 02:45 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
