G35 & G37, Coupes & Sedans
Question on brake padel vibrates
Old Sep 29, 2007 | 10:51 PM
cpthk's Avatar
I have a 05 coupe 5AT. This happens only twice since I bought this car, I step on the break. I can feel the brake vibrates and also hear vibration noise. It just happens on the brake, not other part of the car. Is it normal? ABS?
Old Sep 30, 2007 | 10:11 AM
GR8TG35's Avatar
The ABS system usually gives you a "pulsating" feeling on the pedal.
That is only encountered on severe of heavy braking....
Normally, you should not feel anything thru the pedal.
If you are experiencing vibrations, could be a warped rotor or a worn wheel bearing....
How many miles/services on the brakes?
Old Sep 30, 2007 | 02:04 PM
cpthk's Avatar
Ya, that twice of time I remember are pretty heavy on the high way.
How can I check myself if it's a warped rotor or worn wheel bearing?
But I am pretty sure it's not warped rotor, coz as I said it only happens twice since I bought this car. If it's really like that, it should happen everytime.
miata007
Aug 17, 2015 04:36 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
