Looking to buy used G35...burning oil holding me back
1 5AT here needed his motor replaced after discovering that metal shavings were all over the oil pan. I think the bearings went bad.
The techs actually discovered it on accident as they were replacing the spark plugs seals under warranty. When they popped up the valve cover, they saw the F'd up internals.
You have to check it yourself. If it's low in oil, they fun a consumption test.
If the G has over 75k miles, it may also need 2 new valve covers. As a lot of people are seeing oil pooling around the plugs. Especially #6. Dealer quotes: $700-1000+ to replace the leaking seals.
And my 03 5AT.. They think it was because I used synthetic oil right after the 1st oil change. We are still waiting for Nissan to let the dealership know what happened..I also go to look at the heads and well before I used 76 gas over all others and now I'm told they use some additive in their gas derived from pigs. I had a lot of deposits.
Gary
wow really $1000+ for some valve covers??
sounds like people need to shop around.
Shouldn't take more than 3-4 hours max
3-4 X $80/hr labor = 320 + parts maybe $400
or parts + DIY = way better
Each valve cover is $170, You need (2).
(the spark plug gasket are integrated into the valve cover).
Plus new valve cover gasket: $10 x 2
Total price w/o tax: $360. Add $320 labor : $680
That's in the 700-1000 range I posted above if you add taxes.
He talked about labor being $80/hr not parts. His calculations come out to $720 if a shop did it, close to your $680 figure.
And don't give me none of your jibbajabba!!
I see. I thought he meant Labor total: $320.. Plus cost of parts: Total = $400.
You will have to remove the #6 spark plug to see if it has oil on it.
