G35 & G37, Coupes & Sedans
Radio and A/C controls go out on dash. Help?
Old Apr 14, 2008 | 06:01 PM
Padawan's Avatar
I bought an '03 G35 Sedan about a month ago. I have been extremely impressed so far. About a week ago, though, the radio and A/C controls started blinking out while I was driving. Now they will go out for the most of a 45 minute drive.
The steering wheel controls still work for the radio there's just no display. The A/C continues to work on the last set temp settings, I just can't change them.
I am very new to these cars and don't really know where to start looking for this problem. Any ideas?
Old Apr 14, 2008 | 06:26 PM
RaginRaj11's Avatar
Your circuit board is overheating causing all of the buttons to go out. The dealer will fix it under warranty. I had the same problem.
Old Apr 14, 2008 | 08:22 PM
Beebo's Avatar
its a commen problem with 03-04 G's... if you dont have warranty... might wanna buy aftermarket because thats about how much the dealer will charge you to replace radio/ac
Old Apr 15, 2008 | 12:12 AM
Padawan's Avatar
Can you buy a circuit board aftermarket and replace it yourself? I never have been a big fan of going to a dealer for repairs and I don't have warranty left.
I would like to leave it stock for now so if I could just fix it that would be nice.
Come to think of it, it is worse on days that there is direct sun-light on the dash. It works almost all the time when it's cloudy.
Old Apr 15, 2008 | 12:16 AM
RaginRaj11's Avatar
Im pretty sure you can order the part from Infiniti and replace it yourself. I had the exact same problem with the direct sunlight.
Old Apr 15, 2008 | 01:02 AM
fbw5595's Avatar
I have the same problem. Keep us up to date on your fix.
Old Apr 15, 2008 | 11:44 PM
Padawan's Avatar
Okay, I've been doing some reading on this and it does seem that it is a board behind the finish panel. I am attaching a pic to see if I can confirm with someone that I am on the right trail. I think it should be number 1 in the diagram.
Anyone who has replaced this: How hard is it to get to and is this part available from any place other than dealer?
I can't believe Infiniti hasn't recalled this as many problems as it has caused.
Attached Thumbnails Radio and A/C controls go out on dash. Help?-ac-radio-disassembly.jpg
Old Apr 16, 2008 | 12:22 AM
Beebo's Avatar
im pretty sure the dealer is the only place... and i doubt it will come in that one piece... you will need to buy all of it as one...
look on eBay for used radios but then you cant be sure about those because they could be selling them for the same reason
Old Apr 16, 2008 | 09:47 PM
pattyskin's Avatar
I had exact same problem, got after market DD kit with touch screen nav and climate controls for 1k less than dealer replacement with OEM.... go the DD conversion, you will not regret it.
Old Apr 16, 2008 | 10:18 PM
fbw5595's Avatar
What did the dealer quote you for an OEM?
Old Apr 16, 2008 | 10:49 PM
Padawan's Avatar
Who makes the DD Conversion? I've googled it and haven't gotten close yet.
Old Apr 16, 2008 | 11:13 PM
pattyskin's Avatar
I believe they said 2400 including labor, it was 2 years ago though so I'm not sure.
http://www.grubbsperformance.com/servlet/Detail?no=3060
that is what you need.
G35Rican
Jul 31, 2024 01:37 AM
G35xdriver04
Nov 7, 2015 08:31 PM
JLee301
Sep 25, 2015 08:46 PM
Siciliang35
Sep 18, 2015 11:22 PM
mattdg35
Sep 14, 2015 11:28 AM
