G35 & G37, Coupes & Sedans
Little Tips To Maximize Horsepower W/out turbo/supercharger
Old May 19, 2008 | 09:04 AM
Beebo's Avatar
^ 5/16...
Old May 19, 2008 | 09:19 AM
mt7rabbit's Avatar
1/2" gives you more power (less than 4hp) in the higher rpms but 5/16 gives you the hp at the lower more usable rpms.
Old May 19, 2008 | 06:06 PM
alphabetman's Avatar
What is the biggest difference bwtween
COPPER ISO THERMAL PLENUM SPACER
Old May 19, 2008 | 06:39 PM
officerdbag's Avatar
Test pipes gave me a good amount of power that I could feel for sure.
Old May 19, 2008 | 06:44 PM
CondeNast78's Avatar
From what I understand, the Copper ISO Thermal Plenum Spacer's recommended for any region that sees temperatures that hit near or below freezing anytime during the year, it's a "set and forget" feature. The non-copper ISO Thermal Plenum Spacer's adjustable and is recommended for more temperate regions... I'm a fan of Motordyne Engineering
Hope that helped, you should check out Motordyne's website or do a search on here...
Peace
Old May 19, 2008 | 07:00 PM
SteveBlake's Avatar
Test pipes or High Flow Cats will be the best bang for the buck and after hearing more about them i would get either one over the 5/16 spacer
Old May 19, 2008 | 09:18 PM
SDGeneralCounsel's Avatar
NA mods on the VQ = worthless. Go FI
Old May 19, 2008 | 09:36 PM
Beebo's Avatar
The 5/16 and 1/2 Spacer make more power than test pipes or high flow cats...
Old Jun 16, 2008 | 10:02 PM
dev1983's Avatar
Originally Posted by aLi-KaT
what better? 5/16" Copper ISO Thermal Plenum Spacer or 1/2" Copper ISO Thermal Plenum Spacer
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
NJ6MT
Oct 9, 2015 05:02 PM
danielidiaz13
Engine - Exhaust
Sep 22, 2015 02:57 PM
