G35 & G37, Coupes & Sedans
Little Tips To Maximize Horsepower W/out turbo/supercharger
Old Apr 21, 2008 | 11:24 PM
CondeNast78's Avatar
Question Little Tips To Maximize Horsepower W/out turbo/supercharger
Hey, I bought an 04' coupe and just purchased a Stillen cold air box hi-flow air intake with the z-tube (only produces 6hp at best around 5000rpm). I'm looking for any tips on small mods I can do to increase horsepower without compromising my engine's 'health'...
ps used the "search" function, just hungry for the max amount of knowledge
Old Apr 21, 2008 | 11:39 PM
RaginRaj11's Avatar
The plenum spacer is one of the best bolt on mods. Exhaust, headers and intake will also help.
Old Apr 21, 2008 | 11:42 PM
lekker_droom's Avatar
Agreed. Don't think of the plenum spacer as adding HP per sé, but rather freeing up untapped power. Regardless, plenum spacer is a good mod for a reasonable price.
Old Apr 21, 2008 | 11:43 PM
Thanks for the info Ragin' - just read you have the clear Nissan corners, were they tough to install?
only if you have no fingers.
Old Apr 21, 2008 | 11:44 PM
O HELLA OEM's Avatar
installing clear corners is the easiest mod to do...
Thanks Lekker, hi all from a newbie... I've dug the people I've met in this little community - thoughtful advice, and no turkeys!
cheers from Seattle
Old Apr 21, 2008 | 11:47 PM
Another good, cheap mod, especially for an AT, not sure if you have AT or MT, is a grounding kit. Apex'i came out with a good one and Gordgee's Grounding Gear is among the more popular as well.
Some mag just did a test and tune on a G37 and the grounding kit netted 4 or 5 horses I believe, helps with smoother shifts in an AT as well.
Old Apr 21, 2008 | 11:48 PM
LOL pgh see I'm already asking about mods! It starts with the "little mods", and always gets out of hand!
Old Apr 22, 2008 | 05:21 AM
PoorG35's Avatar
dont forget to checkout the nw side of this forum as well as my350z.com
Old Apr 22, 2008 | 08:30 AM
Beebo's Avatar
to get the most power you will need to build a full N/A engine and that will cost as much as a vortech sc and only get around 300 to the rear wheels
Old Apr 22, 2008 | 08:38 AM
OBG3506's Avatar
Is there a DIY on the plenum spacer? Will the plenum void your warranty?
Old Apr 22, 2008 | 08:49 AM
gary c's Avatar
Just a few mods needed....!
You've got the Stillen CAI/Z-Tube that's a good first mod. Next mod, and the
best for your $ is the MotorDyne 5/16" spacer. It comes with everything you'll need to install....great instructions too. 661-993-5111 Following the spacer a cat-back exhaust along with
high flow cats should complete the needed mods to give you noticable HP
gains. Headers are not worth the PIA to install! Good Luck and Welcome to
Driver....
Old Apr 22, 2008 | 12:08 PM
pullover20's Avatar
FGC general member
Motordyne 5/16" spacer is one of the cheapest mods to give you a little power along with exhuast and high flow cats you should have a noticible gain
Old May 19, 2008 | 02:05 AM
aLi-KaT's Avatar
what better? 5/16" Copper ISO Thermal Plenum Spacer or 1/2" Copper ISO Thermal Plenum Spacer
