G35 & G37, Coupes & Sedans
Debadging question.
Old Apr 25, 2008 | 04:34 PM
k662's Avatar
Debadging question.
I just debadged my G (took the G35 and I N F I N I T I off, left the Mt. Fuji). The adhesive residue left under the INFINITI letters came off with some bug/tar remover and a little clay bar to clean it up, but the adhesive under the 'G35' is proving much more difficult. Rather than being soft like what was under the INFINITI, it is a very hard and wont come off with any amount of scrubbing and rubbing with the bug/tar remover or clay bar.
Do you guys have any suggestions on how to get this off? It is driving me crazy, I spent a good 30 minutes working on it with hardly any progress. Any product recommendations or techniques to remove it would be awesome.
Thanks a lot.
Old Apr 25, 2008 | 06:32 PM
chain492's Avatar
did you use goo gone? that could work.
Old Apr 25, 2008 | 06:59 PM
damafuka's Avatar
goo gone works
Old Apr 25, 2008 | 08:34 PM
k662's Avatar
Thanks, I have something called Goop which I think is essentially the same thing but I had heard that petroleum in it (for degreasing) can be bad for your paint. Ill try it though, thanks again!
Old Apr 26, 2008 | 12:49 AM
Hotdawwgman's Avatar
Gas
worst case scenario, you could use Gasoline!!!DOMO
Old Apr 26, 2008 | 01:01 AM
bigc's Avatar
Wings Nation
use a hairdryer to heat the adhesive up, then hit it again with the Goop. try using some rubbing alcohol on it if that doesn't work - be sure to cleanup thoroughly afterwards.
Old Apr 26, 2008 | 01:10 AM
k662's Avatar
Thanks for the responses. Didn't get a chance to work on it again today, but will try these suggestions out tomorrow morning.
Update: Ok, I got it all off. What worked was heating it for about a minute with a hair dryer then using gas on a clean rag to rub it off. It still took a bit of elbow grease, but that was the only solution that worked for me. Every other combination I tried failed, the gas is what did it.
AT23
Sep 15, 2015 07:44 PM
Terry_G35
Sep 10, 2015 08:17 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
