G35 & G37, Coupes & Sedans
How much to program intellikey?
Old Apr 28, 2008 | 11:50 PM
jtech's Avatar
How much should I be paying to get one programmed? One dealer quoted me $150... Is that too much?
Old Apr 29, 2008 | 01:47 AM
JDMxBALLER22's Avatar
I paid $60 for all the keys to be reprogrammed at the dealer. Make sure you bring them all at once or the ones you don't bring won't work anymore.
Old Apr 29, 2008 | 09:42 AM
Smokey6's Avatar
Check this out - this might work for you (for free!)
http://www.infinitihelp.com/diy/comm...am_key_fob.htm
Old Apr 29, 2008 | 08:56 PM
jtech's Avatar
i actually need programming for the other intellikey... the one with the keyless entry and engine start
Old Apr 30, 2008 | 08:18 PM
theshawn's Avatar
well in reply to smokey the guy at the dealer told me all i had to do was press the buttons down next to each key fob?
Old May 2, 2008 | 09:58 AM
coffeysm's Avatar
I paid about 60 bucks to have my key cut and reprogrammed at Lokey. But, I gave them a key I bought off EBay..
Old May 2, 2008 | 01:43 PM
longbutthair's Avatar
I was also quoted $150 for a programmed key. That included a new iKey and to have it programmed. Not sure from your post, but if you just need your current key reprogrammed, then it should be cheaper. I believe the key is $100, and the programming of it is $50. Perhaps the dealer quoted you a new key w/ programming. Check again.
Old May 2, 2008 | 08:30 PM
jtech's Avatar
i spoke w/ another service advisor at the same dealership. I told her that I had a used one that I needed reprogramming and she told me that it would be $175 just to reprogram it... WTF? the other guy told me $150? I'm thinking that I should call customer service to see if I can get and idea of how much it SHOULD cost
Old May 3, 2008 | 05:47 PM
patrickt888's Avatar
I bought the remote and blank key off ebay. Homedepo cut the key for $2.
I took it to a Nissan dealer & reprogram both remotes and 2 keys for $105 Canadian.
TNRocker
Sep 21, 2015 08:36 AM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
