G35 & G37, Coupes & Sedans
My speedo is accurate.
Old Jun 2, 2008 | 01:34 PM
redlude97's Avatar
Originally Posted by Klubbheads
yes, i know. If it shows 35 mph when im going 40 mph then that means it is off by 12.5% so if im going 150 mph on the tach, that means i am really going 131.25 mph.
this doesn't hold true at higher speeds due to tire slippage and various phenomenon at higher speeds. Even if your tires were OEM diameter, the accuracy will plummet at 100mph+
Old Jun 2, 2008 | 01:35 PM
Klubbheads's Avatar
IBTD list:
1. klubbheads
2. express705
3. CruisnGcoupe
4.
5.
I need two more to make it a fair deletion.
Old Jun 2, 2008 | 01:42 PM
redlude97's Avatar
why delete? seems like there's some good info that salvaged the thread
Old Jun 2, 2008 | 01:44 PM
Klubbheads's Avatar
So what would be an "accurate" way to check the speed of an object that is moving 100mph+?
Old Jun 2, 2008 | 02:14 PM
redlude97's Avatar
With a radar gun at those speeds, what I was saying is to not extrapolate a radar reading at 40mph to your speed at 150mph. The best way to determine the accuracy would be to due multiple runs at a range of speeds with 4-5 repeats per speed, and then you could determine a relatively good fit to the data which you could then calibrate your speedometer to
Old Jun 2, 2008 | 07:55 PM
OCG35's Avatar
my speedo never reads fast enough
Faster, faster, faster!
Msedanman
Sep 21, 2024 07:56 AM
AmateuRN
Apr 7, 2005 06:50 PM
juggernaut
Sep 20, 2004 01:18 PM
cke73
Jul 11, 2004 06:05 PM
suprhulk
Mar 28, 2003 01:14 PM
