G35 & G37, Coupes & Sedans
Help, window button panel fell into door
Old Jul 19, 2008 | 04:35 PM
SCOTT88's Avatar
I was driving to work today and went to roll down the window and the drivers side window/door lock panel buttons fell into the door panel. It looks like the screw that was holding it into place has come undone. The buttons still work and was able to get the window up but are inside the door panel some what.
To screw this back in, I guess I need to remove the door panel cover. Is there a way to do this myself? Has this happen to anyone before? I have a 2003 g35 sedan.
Old Jul 19, 2008 | 06:08 PM
jjyellow's Avatar
Just remove the panel and screw from there. Theres a diy somewhere of replacing the window motor, but it also shows you how to remove the panel. lemme see if i could find it for you
Old Jul 19, 2008 | 06:10 PM
jjyellow's Avatar
I know its for a coupe, but it should be similar for a sedan:
https://g35driver.com/forums/body-interior-exterior-lighting-diy/222829-diy-sticky-window-motor-repairs-door-panel-removal.html
Old Jul 19, 2008 | 06:35 PM
SCOTT88's Avatar
Ok thanks, I will try that when I get home.
Old Jul 19, 2008 | 08:51 PM
SCOTT88's Avatar
Got it off, the door panel piece that has the 4 windows and door lock is cracked where the screws screw in and needs to be replaced. Do you know where I can order this piece online?
Old Jul 19, 2008 | 08:53 PM
shilohap's Avatar
Good luck with that one. Could be a stealership part.
Old Jul 19, 2008 | 09:39 PM
SCOTT88's Avatar
Ok, I may have to check with them next week. I got the screws back it in and it seems to be holding as long as no one pushes the door unlock button with a lot of force.
Old Jul 20, 2008 | 09:16 AM
dave's Avatar
Do you mean this part? Riverside Infitini has pretty good prices and service. There are several on here that you can pm, they are very helpful.
Old Jul 20, 2008 | 04:41 PM
SCOTT88's Avatar
Yes that is the part. It says black. I would need a tan/khaki color.
Old Jul 20, 2008 | 05:33 PM
Sbeck's Avatar
Talk to Mike@riversideinfiniti
He can get you what you need probably.
Old Jul 20, 2008 | 05:59 PM
shilohap's Avatar
Thanks for the "trademotion" link looks like a great site.
Paragham
Sep 15, 2015 12:04 AM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
