G35 & G37, Coupes & Sedans
Dynolicious turns iPhone into cheap performance meter
Old Aug 2, 2008 | 10:55 AM
  #31
OCG35's Avatar
Originally Posted by nismotech1
well i thought my run was fairly accurate, now i've never run my g at the track but without adding the weight for me and my friend it said i had a 2.61 60 ft and ran a 10.07 1/8 and a 15.3 1/4 at 95.4 mph on the street launching around 3k how accurate do those numbers sound to you all? i believe it's all in how you set it up. the only part it got wrong in my opinion is whp it said 179 at the wheels i don't know where it should be but i don't think thats right
Ridiculously slow... I can’t believe you guys are even bothering with this thing...
to each their own I guess... I should start working on some gizmo gimmick... how about a calculator that would convert your 1/4 mile time to tell you how fast you would have ran in reverse? Sound good?… okay send me some $$ I’ll get one right out to you…
Old Aug 3, 2008 | 03:14 AM
  #32
reconJDM's Avatar
woah a dyno meter on the Iphone, I think I need to go pick myself up a Iphone.
Old Aug 3, 2008 | 01:13 PM
  #33
mIKE's Avatar
The phone needs to be litterally, bolted down onto the car, or at least secured very very well so it doesn't move.
Mathematically, it is fairly accurate. Inaccuracies are introduced when it's not perfectly in unison with the car
Old Aug 5, 2008 | 07:00 PM
  #34
Shakuya88's Avatar
Put in the sliding part of the center console and then close the sliding part to "clamp" the iPhone....that will do a lot btter than having it just sitting there.
Old Aug 6, 2008 | 09:44 AM
  #35
vhtran's Avatar
They said it works on iPod touch as well...how does this involve with GPS ? Any idea on iPod touch?
Old Aug 6, 2008 | 12:37 PM
  #36
st1sj's Avatar
http://www.autoblog.com/2008/08/01/d...x-and-dynojet/
Old Aug 8, 2008 | 08:28 AM
  #37
antonucci's Avatar
$13 iPhone App Faces Off Against, Embarrasses $150 Dedicated Dynometer
Old Aug 8, 2008 | 08:31 AM
  #38
Hi-TechG35's Avatar
Interesting! Sort of like a G-Force meter.
Old Aug 8, 2008 | 08:41 AM
  #39
Shakuya88's Avatar
It doesn't use GPS. Hense why the iPod touch and original iPhones can use it. It on'y uses the accelerometer in them. (Same thing that makes the screen turn when phone is turned) It's pretty damn sensitive.
I still havn't found a good place to try it out. No tracks with 3 hours I did a sitting still run with me just angeling the phone different and I got my mom's eclipse to have 1084 FWHP...HAHA and a 10.08 ET @ 134 HAHAHA
Old Aug 8, 2008 | 03:10 PM
  #40
infinus's Avatar
hmmmm I'm gonna try this out, any ideas where I can get the weight of my G? Like a truck scale or something...
Old Aug 8, 2008 | 05:03 PM
  #41
Darkstar752's Avatar
online, i believe the coupe is 3490 and sedan is 3350. Im not sure though so look it up. Also remember to add in your own weight.
Old Aug 8, 2008 | 08:01 PM
  #42
Rob_G35's Avatar
In Search of Magic
I tried it on a side road and it seems pretty accurate. I was kind of afraid of cops so I couldnt take my time with it. But its great for a $13 toy. Here is a video you guys might want to check out. They test the iphone vs. g-tech vs. actual track time. It was off by almost nothing. Here is the link
Old Aug 8, 2008 | 11:28 PM
  #43
infinus's Avatar
Yeah but with options/aftermarket parts I'm not sure how close that is, If i can find a truck scale or a scrap yard that would be awesome so I can get it as accurate as possible.
Old Aug 9, 2008 | 01:17 AM
  #44
r0csfinest's Avatar
how the hell do i calibrate it?
Old Aug 9, 2008 | 01:51 PM
  #45
Klubbheads's Avatar
Like Mike said as long it's secured in the car then it should give u fairly accurate numbers.
