G35 & G37, Coupes & Sedans
Seat heaters (aka butt warmers)...
Old Aug 18, 2008 | 09:46 PM
snopyro's Avatar
Have a 2005 G35 coupe and noticed that when the seat heater switch is initially turned on (low or high setting), it will heat up the seat as expected. You will be able to touch the seat and feel that it is nice and toasty. 10 minutes later, I will notice that the seat is now just "warm" to the touch. Is this how the seat heaters are supposed to work?
Reason I am asking is that I am using an Audi as a comparison which has 5 levels of heating. When you select a particular heat setting- it will maintain that heat setting for as long as it is left on.
In the G35, it seems to reach some preset temperature, then goes into standby mode again. I'm not sure how long it takes to for it to reset itself and actually come on again. Because of this, I've been known to turn the seat heater off and on again to trick the system into thinking I just turned it on again so my seat will get hot again.
Normal for these cars? Or do I have a problem?
Old Aug 18, 2008 | 11:55 PM
Darkstar752's Avatar
I think it's normal, for saftey or something, in my Dad's Range Rover, If you set it on high, it will stay there for like 10 min, go on low after 10, then go off.
Old Aug 19, 2008 | 12:00 AM
Beebo's Avatar
thats not normal... i never put mine on low but when i have it on high it stays hot til i turn it off
Old Aug 19, 2008 | 07:53 AM
g35coupe253z's Avatar
i cant really tell which ever that keeps my *** warm then its fine
Old Aug 19, 2008 | 08:04 AM
GR8TG35's Avatar
I believe the seat warmers "cycle". They heat up to a designated temp, then it turns off and warms up again after a temp loss is detected. Thats how my I35 and my coupe both seem to work. My heated steering wheel on the I35 did the same thing.....I miss the heated Steering wheel, especially in the middle of winter here in Jersey.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
BradMD_96
Oct 6, 2015 09:31 AM
doakley92
Sep 25, 2015 12:58 PM
