G35 & G37, Coupes & Sedans
You Know You Drive a G35 When...
Old Jun 11, 2010 | 10:13 AM
  #256
K Dub's Avatar
Originally Posted by jibberjabbers
When it takes you 3+ tires to fill up the tank. And the person next to you says, "I think it's full", and you don't have a good response, so you drive off just to go along with it and not look like a tool driving a car with so many problems.
Rotate the nozzle 180* (upside down) usually works for me.
Those of us who previously owned Jeeps are used to this common issue.
Old Jun 11, 2010 | 10:29 AM
  #257
bknewtype's Avatar
when u see a cute chick pass by, and u immediately stand next to your car so they notice you and the car
Old Jun 11, 2010 | 11:02 AM
  #258
K Dub's Avatar
Originally Posted by VCG35
When you bust a nut every time you start the car.
Gotta take issue with this one. I wince every time I start the car.
Do you know what it does to the engine of car when you rev it stone cold with 0 oil pressue built up?
God I want to KILL the engineer that integrated that rev into the start up.
Old Jun 11, 2010 | 03:01 PM
  #259
iiiiiekoiiiii's Avatar
Originally Posted by O HELLA OEM
lmao!!!!!! im not the only one
haha Def. not. While im washing mine, my neighbors walkin by go, U know thunderstorms are coming in. All I can say is... Its okay.
Old Jun 11, 2010 | 03:10 PM
  #260
mt7rabbit's Avatar
When you have to replace the window motor or door lock actuator once every 50k miles
Old Jun 11, 2010 | 03:13 PM
  #261
jibberjabbers's Avatar
and $400 for 2 valve covers every 70k..
Compression Rod every 35-60k
front tires every 10-15k (replacing compression rod with new revised rod may fix this problem).
Old Jun 14, 2010 | 02:19 PM
  #262
GrocryGettr's Avatar
...she has to ring out her panties after riding with you!
Old Jun 17, 2010 | 05:21 AM
  #263
kday's Avatar
When you go to the gas station every 4-6 days
errr k
Old Jun 17, 2010 | 07:40 AM
  #264
scrapiron7's Avatar
From spilling a drink?
Old Jun 17, 2010 | 08:50 AM
  #265
xxkylexx's Avatar
Old Jun 17, 2010 | 01:13 PM
  #266
hwa786's Avatar
when you read this whole post and find the one you like and set it as ur facebook status LOL
Old Jun 17, 2010 | 02:30 PM
  #267
kday's Avatar
when buying an extra drink at starbucks is a pain in the arsh
Old Jun 17, 2010 | 07:31 PM
  #268
cshawsg35's Avatar
When your car always pings although you use 93octane.
Old Jun 18, 2010 | 01:00 AM
  #269
dEnbOy.GFM's Avatar
When you're at the gas station and someone asks "Is that a Mazda (or Acura)?" and you /facepalm
When you're unwilling to put a lot of miles on the G but at the same time can't resist driving it...
When you clean your car more than you shower. (Dust the car in the morning before work, when I get to work, when I get off work, and when I get home)
When you get sick of the random rattling in the car and roll your window down to the sweet sound of the exhaust even if it's below freezing outside.
When you're worried about the abnormally loud sound of your clutch/flywheel chatter, spend three hours searching it on g35driver.com only to be told it's normal, then listen to it again and think otherwise, and spend even more time researching only to be told it's normal, then go and listen again and think it can't be normal, then come back to driver and.........................
When someone asks you how much the car is and you tell them what it cost fully loaded at the time it was new instead of what it's worth now or when you bought it used..
oh and when you cause someone to rear-end another person because they were staring at your car driving next to them instead of paying attention to the car in front of them that's stopped waiting at an intersection for a left turn.
Old Jun 18, 2010 | 01:07 AM
  #270
jbizz's Avatar
^^ soooooooooooooooooooooo truee on #2 haha
