G35 & G37, Coupes & Sedans
Window Rattling
Old Aug 28, 2008 | 03:12 PM
roots4x's Avatar
Window Rattling
Is there a proven way to prevent the door windows from rattling when you slam the door shut while the windows are down? I understand there is a lack of stability while they are down so I've come to accept it. Just curious if someone has done anything with this.
Old Aug 28, 2008 | 03:16 PM
sm330's Avatar
I have the same problem on driver's side window.. makes noise when door is slammed, windows down, and when I hit bumps.
Old Aug 28, 2008 | 03:24 PM
roots4x's Avatar
Do you also happen to have problems with water leaking into the window when you go through a carwash? It seems they don't seal very well and a high pressure washer will force water inside (albeit in small harmless drops).
Old Sep 1, 2008 | 02:28 PM
sm330's Avatar
No leaks, but the seal looks like its off about 2mm. I can replicate the noise it makes if i push the button that tells the car the door is closed.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
