drag slicks
Are you looking for a full on slick or a drag radial. The difference is that the radial is usually DOT compliant and can be driven on the street. The radial also has a stiffer sidewall. I would check out Mickey Thompson's web site...
http://www.mickeythompsontires.com/strip.php
They have an ET Street in a 17" that hooks very nicely on the street and the strip.
I do warrent a drag slick but i have bn told that its hard to fit a 15" rim on the g35 b/c of the brake disk clearence. besides all the other posts on here b/c apparently no1 read the original question. what mods r needed to place a rim size that can carry a drag slick ( not drag radial)
we are in the process of doing this to make it for a race feb 22. You will need to run a spcaer to clear the non brembo calipers. Its a tuff thing to explain and can be done better with pictures. I will start the post up soon in the drag section. later mike
