Anyone know it there is a way to change dash colors!
Does anyone know if you can change all of the guage and cluster colors from factory orange to blue. Is there any aftermarket parts or what. Im pretty new to this forum, so any comments will help a tremendous amount.
Welcome to the forum SlickRick777.
A few members have accomplished the change over, but I will warn you it is a labor intensive job.
Search Accordfreak's threads......he successfully changed over his entire lighting to blue. It requires de-soldering and resoldering out each LED Diode.
If I can find the thread I will post it for you
Check This Thread w/Links
Good luck
Good luck
cheapest way is to get some sunglasses and put a colored lens on them, and force your passengers to do the same. So if you want green, you would put a blue lens (cause g35's have yellow-orange guage), or for green, you would do blue.
and you could also buy some HD "wrap-a-rounds" if you want HD
LMAO!!!! I was crying picturing someone I know that may actually try this. Not so bad of an idea tho!
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
