G35 & G37, Coupes & Sedans
TPMS (tire pressure monitoring system)
Old Oct 28, 2008 | 09:05 PM
olwizard's Avatar
I bought 4 Blizzaks from Tire Rack that came mounted on aftermarket rims. The rims aren't equipped with TPMS sensors. Other than not receiving data if my tire pressure drops, am I risking anything else by running rims that don't have TPMS sensors? Thanks
Old Oct 28, 2008 | 09:26 PM
Solid71's Avatar
I thought that the TPMS sensors were transferable.
Old Oct 28, 2008 | 09:30 PM
GEE35FX's Avatar
No problem, many of us run our wheels like that.
Old Oct 28, 2008 | 10:05 PM
BlueDevilBAMF's Avatar
You could just have an installer remove one bead of the tire and swap out the TPMS sensors for the valve stems in your new wheels/tires. Quick and easy.
Old Jun 30, 2009 | 11:47 PM
ThaSaint's Avatar
I am ordering rims that are not compatible with the tpms as per tire rack... is there a way to shut off the warning system if i get the rims??
Old Jul 1, 2009 | 12:30 AM
gary c's Avatar
Aren't Blizzaks winter tires that you guys need to run when that stuff called snow is on the highways? You could just transfer your sensors to the winter tires or put up with the dash warning light for a few months. Make sure you monitor the tire pressure yourself since without the sensors you won't have a back up....
Gary
Old Jul 1, 2009 | 05:49 AM
EL-EE-ES's Avatar
https://g35driver.com/forums/brakes-...-work-etc.html
Old Jul 2, 2009 | 01:21 PM
RADIOGUY21's Avatar
you can run without the TMPS sensors without any problems. The light will come on after about 30-45 minutes of continuous driving. And the light will reset after you restart the car.
RA102223
Aug 15, 2015 09:24 PM
TheKnite
Aug 14, 2015 07:59 PM
TWASkyliner
Aug 1, 2015 11:43 AM
joedaddy1
Jul 28, 2015 02:58 PM
