hvac went out while dd instal: i am freezing please help
Dec 8, 2008 | 03:26 PM
hi, i had just installed pioneed avic700bt and before i even got a chance to plug in the metra harness for the metra ac controls, the hvac unit shut itself off...now i have nothing on the hvac screen and no air or heat. Please help! i have checked the fuse for radio which is indeed intact since the pioneer works fine. Is there a seperate fuse for the hvac located elsewhere besides the battery compartment...any help will be much appreciated! ...FYI i have a 2003 g35 sedan
Reply 0
Dec 9, 2008 | 02:24 AM
dont know if this will help but check the fuses under the steering wheel. Maybe there is a fuse in there.
Reply 0
Dec 9, 2008 | 02:41 PM
as KKARMA said there's fuses by your foot rest. Check those i don't see why your hvac would go out. I just installed my avic-f900 on friday and everything works perfect just that i used the jdm double din
Reply 0
