G35 & G37, Coupes & Sedans
to heat or not to heat
Old Dec 18, 2008 | 10:02 AM
MatthewM's Avatar
Howdy - 2004 Coupe 42K. There is very little heat. At idle it disappears. After running on high the little bit of heat disappears.
Usual suspects? t-stat? air pocket? Someone at O'Reilly's said the gate in front of the core can stick.
The tstat is cheap like $30 - Anyone know how easy that is for DIY?
Would appreciate any help - I don't have the cash for a big service ticket atm.
TIA.
Matthew
Old Dec 29, 2008 | 09:19 PM
Curt G's Avatar
Easiest check is to see that you have enough coolant. If you're low, then you might have an air pocket in the heater core like you mentioned.
Old Jan 12, 2009 | 10:58 PM
Matt93SE's Avatar
Air pocket is the usual suspect on stuff like this...
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
