G35 & G37, Coupes & Sedans
shop's lifts (cars too low to raise it up) need suggestions
Old Dec 20, 2008 | 04:54 AM
DPE_G35's Avatar
hey peeps
i have a promblem, soo my car is dropped on H&R springs (very low drop) and i always have promblems lifting my car at many shops mostly lifts, is there anything i could do? what do most lowered car owners do? buy ramps? need help, im trying to install a y pipe and all the shops told me that "Sorry your car is too low to lift" i have a G37S by the way.
Please help!
Old Dec 20, 2008 | 05:00 AM
jalilig35's Avatar
your shop ur going to is retarded, use ramps to get onto the lift
Old Dec 20, 2008 | 05:03 AM
deeznutts23's Avatar
or just get a jack, put it underneath the diff, and jack the car up to the height that you need. i do it all the time.
Old Dec 20, 2008 | 06:06 AM
DPE_G35's Avatar
i think i got a solution! Takata LDS ramps? does anyone know if i could bring these with me to the dealership when they service my car?
Old Dec 20, 2008 | 09:18 AM
dofu's Avatar
20 Year Member
What kind of lift is it?
If it's a lift you have to drive onto like the ones they use for alignments, use some 2x4s. Watch out as some of these won't have clearance for a car dropped too low.
If it's a lift that has the extendable arms that go under the car, then jack up the rear. Like mentioned a few posts above, use the rear pumpkin as a jack point.
Old Dec 20, 2008 | 12:21 PM
OCG35's Avatar
pics of car?... I wasnt aware of any springs so low that getting on a lift is an issue. adjustable coilovers yes, but springs?
Old Dec 20, 2008 | 12:23 PM
Matthew121's Avatar
wow, just use 2x4's and drive onto them, I learned this when I first lowered one of my cars when I was 16.
Old Dec 20, 2008 | 12:42 PM
intense660's Avatar
use 2x4's for the front tires and jack up the rear end.
Old Dec 20, 2008 | 12:54 PM
gary c's Avatar
Need to get higher....!
My buddys shop where I change my oil has the extendable arm lifts and I'm
to low without lifting the car while he slides the arms under our lift points. My
plan is to carry a couple wooden 1"x 4" slats to drive on, that should work.
Gary
Old Dec 20, 2008 | 01:13 PM
never gone's Avatar
These are perfect. I too am too low for lifts so I had to use these exact ramps last time I had to go on the lift and it worked perfectly.
Old Dec 20, 2008 | 02:49 PM
DPE_G35's Avatar
^ did you have to use the ramps on all 4 wheels for the swing arms to clear or just two in the front?
Old Dec 20, 2008 | 03:03 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
pics of car
Old Dec 20, 2008 | 03:04 PM
yourdoinitwrong's Avatar
Those are what we use for the Corvettes we service and have never had any problems with them so they should work fine for you. We use them under all four wheels. Only thing to watch out for is if the floor underneath the ramps is wet they can slide on you when you are driving onto them. Our shop floor is coated and when it gets wet, especially with tranny fluid or oil, it's extremely slick.
Old Dec 20, 2008 | 04:34 PM
bert039's Avatar
For some reason this doesn't make any sense for me. How do you put them under all four wheels at the same time? Is the top of the ramp lower then the clearance of the car in the middle?
Old Dec 20, 2008 | 05:02 PM
You position the car partially into the lift space, put down the ramps, and drive onto them. You don't put all four down before you drive the car all the way into position otherwise you will be driving the front wheels completely over the back wheel ramps.
