G35 & G37, Coupes & Sedans
G35 Trivia: Identify This Part!! 5AT
Old Dec 27, 2008 | 03:46 PM
mpspeer's Avatar
Patrick
My shifter on my 5AT must be forced out of park to be operated(I should probably say stuck in park, but I force it out, w/e it has been like this for almost a year and I can't !@#$ing stand it).
The big box in the picture is what I believe is wrong, it looks like a motor about the size of a D Battery. I assume it is suppose to move the piece back (small box) to make way for the shifter when I press the brake/shift **** button in, but it doesn't move.
Does anyone know what this piece is called?
When I press my brakes, nothing happens, I have checked and my brake lights DO work and the lights PRND DO light up, so I can assume it is receiving power, does it just need to be replaced?
Please Discuss..., what else should or can I look for to narrow the diagnosis?
Attached Thumbnails G35 Trivia: Identify This Part!! 5AT-dsc_0105.jpg
Old Dec 27, 2008 | 05:46 PM
Darkstar752's Avatar
EDIT: my bad
Old Dec 27, 2008 | 06:02 PM
danielv12's Avatar
shift-lock solenoid, common
Old Dec 27, 2008 | 06:07 PM
erklep's Avatar
100% correct. very common. can be cleaned and lubed or get a new one
Old Dec 28, 2008 | 12:02 PM
mpspeer's Avatar
Patrick
So I can assume that this is more than likely the problem? The other brass looking thing that is in fornt of the solenoid also does not do anything, is it suppose to?
Old Dec 28, 2008 | 01:05 PM
erklep's Avatar
the other brass rod should move when you shift to tiptronic mode
Old Jan 16, 2009 | 11:04 AM
mpspeer's Avatar
Patrick
Alright so I replaced the solenoid and it still doesn't work, what else should I know look for? What else could be the problem?
Thanks
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
Frostbite91
Jul 27, 2015 05:25 AM
laksjd84
Jul 24, 2015 05:12 PM
