G35 & G37, Coupes & Sedans
VDC Slip Can it be damaged???
Old Jan 16, 2009 | 10:39 PM
AaronJP's Avatar
Recently been stuck on ice and had to "rock" my car out... Anyhow Ive noticed that when I have the VDC OFF that I can still see the slip what is happening here?
Is this damaging the vehicle or is it normal... also how can you insure that the slip/vdc is even working correctly..?
Old Jan 16, 2009 | 10:52 PM
O HELLA OEM's Avatar
same with me...it snowed like hell here for the past couple of days and i had a hard time getting my car to move and the BRAKE,VDC OFF,and SLIP lights wont turn off...
Old Jan 16, 2009 | 11:03 PM
AaronJP's Avatar
Well no I had purposly turned my VDC to OFF... then when the car was letting me spin I could still see the slip light flashing from time to time, but no of the lights actually stayed on....
I just didnt know if I damaged my car by turing off the VDC and getting the SLIP light to still activate with VDC OFF... Anyways I dont know if its an electronic thing or something in the car that can be damaged.
Old Jan 16, 2009 | 11:09 PM
GT-ER's Avatar
I think the light just flashes to let you know there is slip...nothing more.
Old Jan 17, 2009 | 09:29 AM
shakin's Avatar
I've definitely seen the light go on while VDC is off, but the functions are still working while VDC is on so I figured it's normal. If there is a problem with the system I think the light will remain on all the time.
Old Jan 17, 2009 | 10:56 AM
Big Nate's Avatar
I think you need to check your brake fluid if your getting all those lights; at least that was what I had to do
As for the original post I was wondering the same thing with mine. I just choose not to acknowledge it anymore, I hope i'm not damaging anything
Old Jan 17, 2009 | 11:07 AM
ttrank's Avatar
Grocery getter
I've had them all come on and stay on after some drifting around. It should reset after turning the car off and letting it sit for a while. If not I agree, check your brake fluid, that is another very common way to turn on those three lights.
Old Jan 17, 2009 | 11:34 AM
G35Now!'s Avatar
Moderation-free
At least on the '07 sedan, it comes on because the wheels are spinning, whether VDC is on or not. It's normal, unless it stays on.
Old Jan 17, 2009 | 11:38 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Also...
VDC set to OFF, is not 100% OFF.
Old Jan 17, 2009 | 11:50 AM
AaronJP's Avatar
Originally Posted by InTgr8r
Also...
What do you mean its not 100% off?
Old Jan 17, 2009 | 03:30 PM
tdelta1000's Avatar
Mine came on after changing a flat front tire. Is it due to a diffecrence in speed?
Old Jan 17, 2009 | 04:18 PM
InTgr8r's Avatar
there are old threads on this info...
guys were look at ways to totally disable VDC, because it was still partially enabled. (but different threshold)
Old Jan 17, 2009 | 07:16 PM
AaronJP's Avatar
Oh I see so thats why when I turned it off I got the still got the SLIP light when I was spinning.
Anyhow another thing do the wipers stop a 1/4 inch from there actual resting spot if you are spraying washer fluid and dont pull the windsheild lever long enough?
Old Jan 17, 2009 | 09:24 PM
AaronJP's Avatar
Also I have noticed that sometimes when Im not getting a SLIP it seems like I am still "slipping" because I am not getting full power plus I hear that pulsing sound like the traction control is engaging.... is that the case considering you can still be slipping for a little bit and not get a slip light?
Old Jan 17, 2009 | 09:35 PM
maciejk's Avatar
prolly possible i think the sensors can't pick up the wheelspin fast enough, so by the time they were to pick it up u have no more wheelspin and the light won't come on, thats what i'm feeling sometimes
