G35 & G37, Coupes & Sedans
VDC/TCS Switch mod
Old Jan 27, 2009 | 09:52 AM
Hydrochoad's Avatar
VDC/TCS Switch mod
I have done a search and looked through all the different info on making a switch to completely shut off the TCS/VDC. I cant seem to find a write-up on the wiring and such. If there is one, can I get a link. If there isnt one, can I get a valid confirmation that it IS the orange wire in the Yaw Sensor Harness under the console that needs diverted to a switch
Thanks
Old Jan 27, 2009 | 05:04 PM
str8dum1's Avatar
use a multimeter and check for yourself? if you dont have a MM, you shouldnt be doin and electrical work to begin with.
Old Jan 27, 2009 | 05:50 PM
infinus's Avatar
Yes it is the orange wire.
https://g35driver.com/forums/2993692-post12.html
Old Jan 27, 2009 | 11:31 PM
Hydrochoad's Avatar
yes I have an MM, and yes Ive done alot of electrical mods. I was just at work when I was reading on it.....
Thanks infinus
Old Jan 28, 2009 | 01:46 PM
infinus's Avatar
No problem, I was contemplating doing this myself, let me know how it works out for you
Old Jan 29, 2009 | 10:52 AM
MidnightG35X's Avatar
Ask KPierson aka KP technologies. He has a module to do this already I believe.
Old Jan 29, 2009 | 02:44 PM
infinus's Avatar
AFAIK all that does is remember if the vdc switch was on or off when turning on the car, no different than flipping the switch. I think there was supposed to be a true vdc disable but they had some problems with it? Unless I'm remembering wrong.
Old Jan 31, 2009 | 12:54 AM
Boog's Avatar
Has anyone tried to intercept and/or alter the data coming out of the g-meter rather than just cutting power to the unit? I realize this would probably be difficult without pulling the unit out, rigging it to a power supply and oscilloscope, and waving the thing around for a while, but it could yield some beneficial results.
If we could use a switch to negate any output (without killing the bite test), we could enable/disable the unit without cycling the key. Additionally, you could use the data to show your lateral Gs without buying other parts.
g.spot
May 9, 2016 10:54 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
RWDguy4238
Sep 30, 2015 12:13 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
