G35 & G37, Coupes & Sedans
cobb access port
Old Feb 10, 2009 | 12:02 AM
steve b.'s Avatar
cobb access port
i just got one the other day tried to get it to work. would not ,called tech support at cobb needed to upgrade firmware did that did not work, called them again they said roms not supported anyways i worked with them for a week could not get it to work finally i gave up sent it back got all my money back except shipping not very happy. what would you guys do instead. need help thanks steve b.
Old Feb 10, 2009 | 03:39 AM
Defratos's Avatar
You're Despicable
Wait what year is your car? if you say 07-08 I'd be freaking out right now
Old Feb 10, 2009 | 04:56 AM
FenixL1P's Avatar
i saw one of the vendors selling the cobb tuner for 695 and was tempted too despite only having the plenum spacer installed... i'll have to wait for more reviews then....
Old Feb 10, 2009 | 09:33 AM
steve b.'s Avatar
cobb access port
my car is a 06 i paid 625 for the cobb but it does not matter how much if it does not work. steve b.
Old Feb 10, 2009 | 10:08 AM
HarrisonK's Avatar
I want one of these for an 04 coupe, but I dont know if it will work
Old Feb 10, 2009 | 11:20 AM
BostonG6spd's Avatar
what does a cobb do exactly? Tune?
Old Feb 10, 2009 | 11:36 AM
FenixL1P's Avatar
^ at least that is what it is advertised to do.
Old Feb 10, 2009 | 11:38 AM
HarrisonK's Avatar
Here is a brief description:
Cobb Tuning Nissan 350Z/G35 AccessPORT
Nissan 350Z/G35 2003-06 ; MT and AT, Coupe and Roadster
The AccessPORT is the most user friendly reprogramming device for your vehicle's computer. The provided mapping will optimize the air/fuel ratio and ignition timing, remove the speed limiter, and more for performance results you can instantly feel!
But the AccessPORT is so much MORE than just a REFLASH DEVICE. It allows you to monitor your Fuel Economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decipher ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for costly and cluttering aftermarket gauges! With the added ability to adjust timing and idle, the AccessPORT is truly more than just a programmer, it is the ultimate all-in-one solution for the 350Z enthusiast.
Nissan 350Z AccessPORT features are as follows:
» Improve horsepower, torque, and fuel economy at the touch of a button
» Adjust timing +/- 2 degree's
» Adjust idle +250rpm
» Display vehicle data such as RPM, temperatures and more while you drive
» Easy installation, no mechanical or computer skills necessary
» Connects to your vehicle via the OBD-II port conveniently
» Exclusive ability to switch between different 'modes' on the fly
» Pre-calibrated to maximize performance of stock or modified vehicles
» Easy-to-read color display
» Update over the Internet to stay up-to-date with the latest features
» Read engine trouble codes (DTC) yourself, eliminating trips to the dealership
» Not a "piggyback" - once vehicle's computer has been programmed by the AccessPORT, it can be removed and the settings will stay on your computer.
» Not just an "ECU reflash" - AccessPORT features enhancements such as on-the-fly mode switching, data monitors, reading DTCs, performance monitors and more
» Can be custom tailored to your vehicle by our extensive network of professional tuners
Old Feb 10, 2009 | 09:37 PM
steve b.'s Avatar
sounds good if it would work
Old Feb 10, 2009 | 09:41 PM
twin001's Avatar
Osiris from Uprev, 'nuff said. Plus, for about the same price you get Cipher.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
linedr89
Aug 17, 2015 05:11 PM
