G35 & G37, Coupes & Sedans
How come Turbo G's aren't as fast as they should be?
Old Feb 27, 2009 | 01:09 AM
  #31
SCXR's Avatar
Originally Posted by GT-ER
Thanks. Here is a picture.
And this was the engine bay taken by my cel phone...lol.
The GP could not do a single thing better than my G so no regrets here...except be easier to mod. Hopefully when I start getting my new pay checks ( I just got a promotion..weee ) I can fix the only thing I don't fully enjoy about my G.
Nice. My last car was a Pontiac too. Our old cars look somewhat related.
Old Feb 27, 2009 | 02:54 AM
  #32
Lucky-G's Avatar
MMMMMMMM Goat...5.7 or 6.0?
Old Feb 27, 2009 | 12:15 PM
  #33
SCXR's Avatar
5.7. It was a 2004. Plenty of power for me though.
Old Feb 27, 2009 | 04:22 PM
  #34
terrycs's Avatar
Buick GN/GNX can be built up cheap for a quick 1/4 mi time. The Gs suspension/drive train is simply not set up for optimal high power launches. But a quick 1/4 car will never be as stable on the freeway at twice the national speed limit.
Old Feb 27, 2009 | 04:36 PM
  #35
dwrecckk's Avatar
My question for when I bought my car 2 months ago, was.... how come the G isn't as it should be STOCK. I mean, on paper it sounds great. 3500 balanced by 300hp doesn't seem underpowered, it has huge brakes and a well balanced chassis. But whenever I drive it, it doesn't feel sporty. It feels a bit sluggish and generally like a huge object. It's odd that they only run a mid 14 as well. The new g37 can run a 13.5 stock. That's almost a full second difference. From only 35hp and a slightly heavier body? It doesn't add up in my mind.
Old Feb 27, 2009 | 05:39 PM
  #36
terrycs's Avatar
The power is there on a boosted G. The problem has always been putting it down.
Old Feb 27, 2009 | 07:17 PM
  #37
GT-ER's Avatar
This is what I wanted to get at.
Where does the problem begin and where does it end? What goes first? Axles, Diff, Tranny? If it's a built auto ( which I see they can handle well over 600whp built ) then it the auto should be much easier on the drivetrain as is. But how hard ( or weak ) are the other drivertrain components? 600whp SHOULD put a full weight G35 into the 10's with ease if you use a high stall converter and quick spooling turbos with slicks. I say SHOULD cause it's always easier said then done.
Old Feb 27, 2009 | 07:53 PM
  #38
da mayor's Avatar
i thought about building a fully built G sedan as a sleepr but it would've looked funny w/ some huge slicks in teh rear like my friend Rocky's Z that ran 10.5@135 built from vinnytenracing.com... The suspension can hold it but the axle upgrade is a must.
Old Feb 27, 2009 | 08:11 PM
  #39
mishap's Avatar
It's the torque curve. 300hp sounds like a lot but it's only backed by 260lb-ft of torque fairly high in the rev band. Coupled w/ a 3500lb chassis and it won't be all that fast. Put the torque curve of the IS350 on the same scale and you'll see the IS makes a bit more torque down low and for a longer period. Considering all the fancy technology they have to wrangle into the IS motor to make that powerband wider(direct injection, dual injectors, & high compression), its no wonder the the G is relatively slower to 60 and so much cheaper. So despite weighing almost the same and having similar hp #'s, the IS 0-60 is sub 5 seconds and on par w/ the G37. That and the 6spd auto shifts better than most people in manuals.
Old Feb 27, 2009 | 08:19 PM
  #40
lovemyg88's Avatar
So what you are trying to say is that the IS350 is faster than a G?
Old Feb 27, 2009 | 09:15 PM
  #41
mishap's Avatar
Would you argue its not? Assuming Toyota didn't underrate their motor, given similar stock hp levels you don't see a lot of 13 flat times out of stock first Gen G35's even Rev ups. Of course IS350's dyno significantly higher than G35's so it's possible the IS is working w/ a bit more power to begin w/. My brother's IS350 definitely would take me in a race and I'm assuming our 20's would slow us down equally of course.
Old Feb 28, 2009 | 02:23 AM
  #42
Lucky-G's Avatar
That's HILLARIOUS. There's a GN in my parent's garage right now that just got BUILT over the winter. We're expecting 9.30's out of it...
You can kind of see it in that pic. It's a MONSTER. I'll post up a mod list if anyone's interested...I'll have to dig it up from TurboBuick forums
Old Feb 28, 2009 | 05:22 PM
  #43
vrezhg's Avatar
Originally Posted by Glex25
1) we have alot of drivetrain loss specially since we use a multi piece driveshaft(18% drivetrain loss on a 6MT).
2)independent rear suspension known for wheel hopping
3) can't drop the clutch again cause of wheel hop
4)Weight
5)Axles have been know to break when using slicks
^^^^ THat.... JUST... happened.. lol
Old Mar 1, 2009 | 12:58 AM
  #44
4DGS's Avatar
It's because gran prixs are ugly and G35s aren't.
Old Mar 1, 2009 | 01:23 AM
  #45
Lucky-G's Avatar
^^ True statement...yah, I'd back that up with fact...yup definitely would.
