G35 & G37, Coupes & Sedans
Grounding wires cause smog
Old Feb 27, 2009 | 07:57 PM
ballisticus's Avatar
So I move from Washington state to California on a 12 month contract. I go to DMV to register, they say I need a smog check. I go to get the smog check and after waiting my turn for an hour the guy says my grounding wires are an illegal modification, I fail the smog inspection. Grounding wires. LOL!
What a phucked up state, no wonder its broke.
Old Feb 27, 2009 | 07:59 PM
Heist.'s Avatar
yeah I hate my state so many laws and regulations I feel like if I change anything it will be illegal in some way or form. I have never heard of grounding wires being illegal though thats just too much.
Old Feb 27, 2009 | 08:00 PM
beezy619's Avatar
Grounding wires have no effect on emissions. Rip that guy a new one and make him give you a refund.
Old Feb 27, 2009 | 08:05 PM
SxExCx's Avatar
welcome to Cali ...lol
Old Feb 27, 2009 | 08:14 PM
rookie's Avatar
No performance difference = no smog difference.
Old Feb 27, 2009 | 09:13 PM
Mustang5L5's Avatar
Lol, a simple ground wire fails smog?? Haha
Can you go to another station?
Old Feb 27, 2009 | 11:46 PM
He didnt charge me. Just opened the hood, called me over, and said anything added that may effect the function of the OEM sensors etc is an automatic fail of the visual inspection. I just removed the obvious wires tonight and tucked the ECU one back behind the battery cover. Took like 5 minutes. Im going to go back tomorrow morning, but its just so stupid and inconvenient
Old Feb 28, 2009 | 01:08 AM
Red_G35's Avatar
what a jackass, you should have given him a piece of your mind.
Old Feb 28, 2009 | 12:07 PM
kernel's Avatar
SEC > Big 12
more reasons I don't want to live in Cali
Old Feb 28, 2009 | 12:22 PM
The Stimulation's Avatar
Tell him if that's the case then anybody with an audio setup, ANY and EVERY vehicle should not pass smog.
All electrical equipment need a source, a positive and negative source. It could be the battery or the chassis. You can actually even use the alternator as well. The chassis ground the entire vehicle. Rather than running a wire say in the trunk for an amplifier all the way to the battery (although sometimes better) you can wire it in the rear onto the chassis. Stock parts use grounds, otherwise they won't work...and that moron tells you it doesn't pass smog? Speak to a supervisor.
Old Feb 28, 2009 | 12:36 PM
Well, it passed, but barely. Was 54 ppm on the HC @ 15 MPH. Right at the max. Probably due to the reflash fuel ratio being based on testpipes being on before. Was richened up quite a bit over stock based on the dyno results. Or maybe cats not fully warmed up, who knows.
This smog deal only has to happen every 2 years right? Luckily I'll be out of here in a year anyway. Good thing they dont know how to do motorcycles yet because that thing would never pass.
Old Feb 28, 2009 | 12:47 PM
It's every 2 years as you stated. I wonder how mine will go next year since i have a muffler delete. I may end up having to go to a place that would just give you the certificate that says you passed. Once I get smog passed, I'll get my custom exhaust with HFC so I don't have to worry about taking off and putting back on.
Old Feb 28, 2009 | 05:26 PM
vrezhg's Avatar
what the... grounding wires just make the car work faster and more efficiently usually.. iono how that can effect ur smog
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
