G35 & G37, Coupes & Sedans
Vibration on highway HELP?????
Old Mar 26, 2009 | 04:43 PM
alliedtech's Avatar
i have a fvcking vibration on the highway it starts at around 65mph right at fvcking crusing speed and gets worse as i let off the gas pedal goes away as i hit the gas pedal again, then after 80mph it goes away, 4 brand new tires with balancing didn't help Any ideas??
Old Mar 26, 2009 | 05:30 PM
Mustang5L5's Avatar
Try rotating the tires. See if that lesses or increases the prob.
I had the same problem. Nailed a pothole this winter and dented up a stock rim on the inside. Got it rebalanced and it didn't fix the prob really. Luckily I have the full size spare option so i just swapped the tires and run the spare as my primary and the dented rim as my spare now
Old Mar 26, 2009 | 05:34 PM
keff108's Avatar
Its def gotta be the tires. Happened to my brother in his Max and he just took it to a tire place and they balanced them and problem solved.
Old Mar 26, 2009 | 05:40 PM
1SlowSedan's Avatar
The same things been happening to me it happens between 60 to 65. I even swapped wheels and it still does it. Anyone know what's up?
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
