G35 & G37, Coupes & Sedans
Ticking noise.....Anyone ever have this problem?
Old Apr 1, 2009 | 01:49 PM
sleev-les's Avatar
Okay, so I have been sick the past couple days so my car has been sitting. I also live on a hill. That being said, I went to go get some lunch today so I can just get out of the house for a bit and I go to start my car, and I hear a valve ticking and white smoke come out of the exhaust. After a few seconds the noise goes away and the smoke was only a brief second. I have never had this issue before, but it has not sat on my hill for more than 24 hours before. Anyone think it is something to worry about? Or maybe just because it sat on a hill and the oil sat to teh front of the engine?
Old Apr 1, 2009 | 02:45 PM
maciejk's Avatar
white smoke is usually blown head gasket if its constant, valve clicking should only be brief after startup if you let the car sit in a very cold weather
Old Apr 1, 2009 | 02:52 PM
sleev-les's Avatar
this is definitely the only time ive seen the white smoke. plus i checked the oil just to make sure no coolant was getting in. im thinkin sitting on a hill for a while may have caused it
Old Apr 2, 2009 | 12:43 PM
OBG3506's Avatar
You sure that the white smoke wasnt just condensation?
Old Apr 2, 2009 | 01:59 PM
sleev-les's Avatar
It had an odd smell to it. otherwise, i would have went the condensation route. hasnt happened since though. makes no sense.
Old Apr 3, 2009 | 09:40 AM
OBG3506's Avatar
Condensation has a smell and as for the ticking mine ticks like its about to go off, dealer said its nothing to worry about
Old Apr 3, 2009 | 11:09 AM
g35ryder19's Avatar
some times its the injecters when u let the car sit for a while
Old Apr 3, 2009 | 11:21 AM
Hi-TechG35's Avatar
Sounds like rings. You might have piston slap.
Old Apr 4, 2009 | 12:47 AM
RussianMan's Avatar
i had some ticking noise when i installed my hfc but all went away after i changed my exhaust gaskets, i didnt have leak but when i block the mufler it was licking so decided to change them and ever since never had the noise
Thebaws11
Jul 2, 2021 11:36 AM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
