G35 & G37, Coupes & Sedans
Too late to debadge??
Old Apr 21, 2009 | 12:41 PM
AVATAR77's Avatar
Is it too late to debadge my OB '05 sedan? I was thinking that I'd like to remove the "I N F I N I T I" from the rear, as well as the "G35," but I am concerned that the paint underneath will be darker as it hasn't been exposed to four years of sun and weather.
Old Apr 21, 2009 | 12:47 PM
DG_coupe's Avatar
i just took my infiniti signs off my 04 coupe and the paint looks fine, good luck
Old Apr 21, 2009 | 12:49 PM
keff108's Avatar
you'll be fine
Old Apr 21, 2009 | 01:16 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by AVATAR77
Is it too late to debadge ............I am concerned that the paint underneath will be darker as it hasn't been exposed to four years of sun and weather.
If it is darker don't worry, it will fade in a few days.
Even on my 08 it was darker & it blended in no time
Old Apr 21, 2009 | 01:27 PM
AVATAR77's Avatar
Cool...now I will have to go find a "how-to"...
Old Apr 21, 2009 | 01:30 PM
Foques's Avatar
warm it up, and pull it off
heatgun/hairdryer will help you with that..also, grab some googone.
Old Apr 21, 2009 | 05:22 PM
Mustang5L5's Avatar
You can almost take them off with your fingernail.
I use floss with a little WD_40 as lubricant and "saw" the letters off. Then googone takes care of the rest
Old Apr 21, 2009 | 05:25 PM
BRice63's Avatar
yup
i'd advise NOT to use a heatgun though cause its possible to wreck your paint if you arent careful with one of them
Old Apr 21, 2009 | 05:30 PM
BigGrz's Avatar
I used a hair dryer to heat up the letters, then slid some floss behind them to get them off. Then cleaned up the left over goo with 'Goo Gone'. Voila!
HarrisonK's Avatar
soak everything in WD40 or some kind of car bug/tar remover for about ten min. Then take off the letters. Then when the residue is left behind, soak that in the WD40 or bug/tar remover for an additional ten min. After that you will be able to "roll" off the rest of the adhesive.
Old Apr 21, 2009 | 07:37 PM
Vrod-Mike's Avatar
Here's a DIY
https://g35driver.com/forums/body-in...ics-video.html
Old Apr 21, 2009 | 07:47 PM
pczavala's Avatar
hmmm i might just do it also, i have a 07 and my MT Fuji is starting to break, well the chrome is like coming off, too many washes i guess.
Old Apr 21, 2009 | 10:20 PM
mysterymann's Avatar
I removed the G35 but it shows up lighter than the paint what should I do??
It is a Laser Red Coupe
Old Apr 21, 2009 | 10:23 PM
Blue Meanie's Avatar
Put masking tape over the marks that are left. No-one will noticed the fading then.
HarrisonK's Avatar
^ clean it and wax it well. Then let it sit out in the sun for a few days, don't keep it in a garage. The lighter area where the G35 was should fade away soon. You may still have an outline of the letters if you look closely. Over time everything will fade away.
