ok, i tried posting in the "right" section
and my thread got 1 view, which was probably me.. so im asking if you have your car aligned on worn tires, and then mount new tires.. will the new tires cause need of a realignment???
https://g35driver.com/forums/brakes-...orn-tires.html
yea, i didnt have money for everything last year, so i had it aligned before i bought new tires... the old tires were bad on the sides they were worn, no tread (when it was aligned).
im trying to point my money in the right direction, so i guess taking it to the alignment shop and having them check that and for any other possible obvious cause would be better to have the wheel balance checked.
Like I said, it's theoretically possible, but unlikely. Get the new tires and have the place where you got the alignment check it again. Most places will check the alignment for free. If it doesn't need it, you drive away. If it does, you either drive away or pay to have it re-aligned. But unless you've hit some large hole or bump since the alignment, you probably won't need one.
