G35 & G37, Coupes & Sedans
Compression rods/Front suspension...
Old May 6, 2009 | 11:12 PM
Realtor's Avatar
Has anyone had this failure yet? The bushing on the front lower A-arms start cracking and causes alignment to change? I have been told the only way to fix this is buying new lower arms(revised).
Any other alternatives? Solid aluminum bushings to replace rubber, etc.
thanks.
Old May 7, 2009 | 12:25 AM
pwebb's Avatar
the alternative is buying just the bushings. on the aluminum arms (rwd) they can be pressed out. awd arms are steel and will most likely need a rull rod replacement as they will more likely than not be rusted out. this is not much cheaper, as the labor would still be the same.
I would not recommend this job as a DIY...
Old May 7, 2009 | 05:40 PM
Mustang5L5's Avatar
https://g35driver.com/forums/brakes-...otal-crap.html
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
yosip1115
16
Sep 28, 2015 04:14 PM
